[gdal-dev] Alpine, gcc 32-bit in Linux Build Actions
Even Rouault even.rouault at spatialys.com
Fri Mar 1 07:12:27 PST 2024
Your code must be something terrible so that even gdb doesn't catch it
:-) (SIGKILL cannot be caught...)
 From the error messages, things might go wrong starting with
https://github.com/OSGeo/gdal/blob/master/apps/test_ogrsf.cpp#L782
So maybe set a breakpoint at that line
b test_ogrsf.cpp:782
and then use "step", and "next" to single step and locate where this
crashes. This is going to be a bit tedious...
(you might also want to modify slightly test_ogrsf so that this
TestCreateLayer() method exists early when
!EQUAL(poDriver->GetDescription(), "miramon") to avoid debugging other
drivers)
You might install "ddd", as a GUI front-end for gdb, so that this is
slightly more user friendly.
http://www.spatialys.com
