[gdal-dev] [External] : Re: GDAL build on windows failed for FILEGDB driver
Fengting Chen fengting.chen at oracle.com
Sat Mar 2 10:01:54 PST 2024
Thanks, removing ‘+’ helped. But the next error is the link error:
E:\SDK\curl-8.6.0_1-win64-mingw\bin\libcurl-x64.dll : fatal error LNK1107: invalid or corrupt file: cannot read at 0x2C0 [E:\gdal-3.8.4\build\GDAL.vcxproj]
The cmake option is:
set (GDAL_USE_CURL                ON   CACHE  BOOL "" FORCE)
set (CURL_INCLUDE_DIR             "E:/SDK/curl-8.6.0_1-win64-mingw/include" CACHE PATH "" FORCE)
set (CURL_LIBRARY_RELEASE         "E:/SDK/curl-8.6.0_1-win64-mingw/bin/libcurl-x64.dll" CACHE FILEPATH "" FORCE)
Any idea?
Date: Friday, March 1, 2024 at 5:54 PM
To: Fengting Chen <fengting.chen at oracle.com>, gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: [External] : Re: [gdal-dev] GDAL build on windows failed for FILEGDB driver
Le 01/03/2024 à 20:31, Fengting Chen via gdal-dev a écrit :
I am using VS2015 terminal and cmake to build GDAL on windows. I got the following compilation error for filegdbindex_write.cpp. Any idea?
I kind of remember there was a ticket about that (probably closed). Basically VS2015 has incomplete C++11 support. You might go over that issue by replace the +[] lambda pattern with just [] I believe. But you'd better upgrade your compiler. The 3.9 branch requires C++17 support, which requires VS2017
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!N7D9wGetkwWAVmRFBxeY1vj2M5dCjlmEJYIu4L8eVIiyJGITK8KWuYu9jFqHfduaiEuEc8PCCTOJ51txLyg4nXpErfxk$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240302/624d1583/attachment-0001.htm>
