[gdal-dev] [External] : Re: GDAL build on windows failed for FILEGDB driver
Even Rouault even.rouault at spatialys.com
Sat Mar 2 10:08:37 PST 2024
> set (CURL_LIBRARY_RELEASE
> "E:/SDK/curl-8.6.0_1-win64-mingw/bin/libcurl-x64.dll" CACHE FILEPATH
> "" FORCE)
==> XXX_LIBRARY[_RELEASE/_DEBUG] should point to a .lib import library,
not to the .dll directly
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240302/90b9faa5/attachment.htm>
