[gdal-dev] [External] : Re: GDAL build on windows failed for FILEGDB driver
Fengting Chen fengting.chen at oracle.com
Sat Mar 2 10:36:30 PST 2024
That is what I guessed. But the documentation says:
CURL_LIBRARY_RELEASE•<https://gdal.org/development/building_from_source.html#cmdoption-arg-CURL_LIBRARY_RELEASE>
Path to a shared or static library file, such as libcurl.dll, libcurl.so, libcurl.lib, or other name.
If I use .lib here, will GDAL link with the dynamic library by default or I need to set CURL_USE_STATIC_LIBS=OFF explicitly?
Thanks!
Date: Saturday, March 2, 2024 at 1:08 PM
To: Fengting Chen <fengting.chen at oracle.com>, gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [External] : Re: [gdal-dev] GDAL build on windows failed for FILEGDB driver
set (CURL_LIBRARY_RELEASE         "E:/SDK/curl-8.6.0_1-win64-mingw/bin/libcurl-x64.dll" CACHE FILEPATH "" FORCE)
==> XXX_LIBRARY[_RELEASE/_DEBUG] should point to a .lib import library, not to the .dll directly
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!JLgqR0Xmpy0AUkdrzdfKyclw3MYEvcOPpYdP04m-uxbTA0uf-YWzEltfLKASB4MXKlj9dC0VOJFC_d3zpeRnm3HTUWIn$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240302/6d1072f9/attachment-0001.htm>
