[gdal-dev] [External] : Re: GDAL build on windows failed for FILEGDB driver
Fengting Chen fengting.chen at oracle.com
Sat Mar 2 12:14:23 PST 2024
Thanks, that is clear now.
One more question, anywhere to get proj_9_3.lib and sqlite3 .lib, most downloadable package only has .dll.
Date: Saturday, March 2, 2024 at 1:50 PM
To: Fengting Chen <fengting.chen at oracle.com>, gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [External] : Re: [gdal-dev] GDAL build on windows failed for FILEGDB driver
Le 02/03/2024 à 19:36, Fengting Chen a écrit :
That is what I guessed. But the documentation says:
CURL_LIBRARY_RELEASE•<https://urldefense.com/v3/__https:/gdal.org/development/building_from_source.html*cmdoption-arg-CURL_LIBRARY_RELEASE__;Iw!!ACWV5N9M2RV99hQ!NL4-GXTlZwB0Rdq69N2ze_aa3cG4M6vhEC97pm9UK8Z4svrhYWwpPuQCNPHu5W_Hlg5OKvssXsXDmBSjEJTiAlZbxGK0$>
Path to a shared or static library file, such as libcurl.dll, libcurl.so, libcurl.lib, or other name.
Ah that was misleading indeed. Correction queued in https://github.com/OSGeo/gdal/pull/9371<https://urldefense.com/v3/__https:/github.com/OSGeo/gdal/pull/9371__;!!ACWV5N9M2RV99hQ!NL4-GXTlZwB0Rdq69N2ze_aa3cG4M6vhEC97pm9UK8Z4svrhYWwpPuQCNPHu5W_Hlg5OKvssXsXDmBSjEJTiAng9m6OA$>
If I use .lib here, will GDAL link with the dynamic library by default
You need to point to the appropriate .lib: a static .lib if you want static linking, or an import .lib for dynamic linking. Cf https://stackoverflow.com/questions/8019464/a-static-library-vs-an-import-library-on-the-windows-platform<https://urldefense.com/v3/__https:/stackoverflow.com/questions/8019464/a-static-library-vs-an-import-library-on-the-windows-platform__;!!ACWV5N9M2RV99hQ!NL4-GXTlZwB0Rdq69N2ze_aa3cG4M6vhEC97pm9UK8Z4svrhYWwpPuQCNPHu5W_Hlg5OKvssXsXDmBSjEJTiAtL66jH4$> for example
| or I need to set CURL_USE_STATIC_LIBS=OFF explicitly?
No, this setting is only effective when set to ON (it adds a -DCURL_STATICLIB define when including curl, and links to a few system Windows .lib).  You need to point CURL_LIBRARY_RELEASE to the appropriate kind of .lib given the type of linking you wish. The exact naming will depend on how curl has been built.
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!NL4-GXTlZwB0Rdq69N2ze_aa3cG4M6vhEC97pm9UK8Z4svrhYWwpPuQCNPHu5W_Hlg5OKvssXsXDmBSjEJTiAvgpGpx2$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240302/68422ce3/attachment.htm>
