[gdal-dev] GDAL_ENABLE_DRIVER_PDF
Even Rouault even.rouault at spatialys.com
Wed Mar 6 02:19:33 PST 2024
I suspect that the error comes from the fact that one of several of the
other dependencies required by pdfium are not found: JPEG, PNG,
OpenJPEG, lcms2
Even
Le 06/03/2024 à 11:00, Johannes Paul via gdal-dev a écrit :
> Hello,
> I have compiled PDFium from
> https://github.com/rouault/pdfium/tree/master and I'm trying to get
> GDAL 3.8.4 built with this geospatial PDF driver on Almalinux 8.
> However if I use cmake with the following variables :
> /-DGDAL_USE_PDFIUM=ON -DGDAL_ENABLE_DRIVER_PDF=ON
> -DPDFIUM_INCLUDE_DIR="${INSTALLDIR}"/include/pdfium
> -DPDFIUM_LIBRARY="${INSTALLDIR}"/lib/pdfium/libpdfium.a/
> I get the following error :
> /CMake Error at cmake/helpers/GdalDriverHelper.cmake:284 (message):
>   gdal_target_link_libraries(): PRIVATE is a mandatory argument.
> Call Stack (most recent call first):
>   frmts/pdf/CMakeLists.txt:53 (gdal_target_link_libraries)/
> If I remove /-DGDAL_ENABLE_DRIVER_PDF=ON /, I get GDAL compiled but
> without PDFium.
> Any idea?
> Thanks,
> Johannes
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240306/62943e60/attachment.htm>
