[gdal-dev] GDAL_ENABLE_DRIVER_PDF
Johannes Paul johannespaul92 at gmail.com
Wed Mar 6 06:25:28 PST 2024
Thanks for your answer Even, lcms2 was indeed a missing piece, it allowed
me to get GDAL configured but the build failed with a missing header:
*fatal error: core/fpdfapi/page/cpdf_page.h: No such file or directory*
I finally used your pre-built binaries from
https://github.com/rouault/pdfium_build_gdal_3_8/releases
And get GDAL to compile properly with pdfium.
Thanks for the support,
Johannes
On Wed, 6 Mar 2024 at 11:19, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> I suspect that the error comes from the fact that one of several of the
> other dependencies required by pdfium are not found: JPEG, PNG, OpenJPEG,
> lcms2
> Even
> Le 06/03/2024 à 11:00, Johannes Paul via gdal-dev a écrit :
> Hello,
> I have compiled PDFium from https://github.com/rouault/pdfium/tree/master
> and I'm trying to get GDAL 3.8.4 built with this geospatial PDF driver on
> Almalinux 8.
> However if I use cmake with the following variables :
> *-DGDAL_USE_PDFIUM=ON -DGDAL_ENABLE_DRIVER_PDF=ON
> -DPDFIUM_INCLUDE_DIR="${INSTALLDIR}"/include/pdfium
> -DPDFIUM_LIBRARY="${INSTALLDIR}"/lib/pdfium/libpdfium.a*
> I get the following error :
> *CMake Error at cmake/helpers/GdalDriverHelper.cmake:284 (message):
> gdal_target_link_libraries(): PRIVATE is a mandatory argument. Call Stack
> (most recent call first):   frmts/pdf/CMakeLists.txt:53
> (gdal_target_link_libraries)*
> If I remove *-DGDAL_ENABLE_DRIVER_PDF=ON *, I get GDAL compiled but
> without PDFium.
> Any idea?
> Thanks,
> Johannes
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240306/c9dc4bc1/attachment.htm>
