[gdal-dev] Renaming multiple layers when loading gpkg into postgis
Richard Duivenvoorde rdmailings at duif.net
Thu Mar 7 10:42:08 PST 2024
Loading a gpkg with multiple layers (from a zip) into Postgis is a breeze (all PG-stuff from env):
  ogr2ogr -overwrite -f PostgreSQL PG:"schemas=target" /vsizip//home/richard/data/data.zip/this.gpkg layer1 layer3
but now I want to rename those layers
  ogr2ogr -overwrite -f PostgreSQL PG:"schemas=target" /vsizip//home/richard/data/data.zip/this.gpkg layer1 -nln betterlayer1 layer3 -nln betterlayer3
This only loads the last layer.
Tried to google for this, but asking here: is it only possible to rename one layer per ogr2ogr call? (while it is possible to load several layers)
If so I will make my scripts do the loading one by one, but just want to check.
Regards,
