[gdal-dev] (no subject)
Shaima Alsharif salmanami22 at gmail.com
Fri Mar 8 01:58:21 PST 2024
Dear Developers,
I am reaching out to seek advice or potential solutions regarding the
creation of .aux.xml files for GeoTIFF Or GOG using GDAL. I have attempted
using the following commands, like so:
os.environ['GDAL_PAM_ENABLED'] = 'YES'
os.environ['GDAL_GEOREF_SOURCES'] = 'WORLDFILE,PAM,INTERNAL'
os.environ['ESRI_XML_PAM'] = 'TRUE'
gdalwarp -overwrite -t_srs EPSG:4326 -r cubic
JED240207122504.MAXBERJ  output.tiff
gdaldem color-relief -alpha output.tiff titan.txt output.colored.tiff
gdal_translate -of COG -co TILING_SCHEME=GoogleMapsCompatible -co
COMPRESS=LZW  output.colored.tiff  output.cog.tiff
gdal_translate -of GTiff -co TILED=YES -co COMPRESS=DEFLATE input.tif
output.tif --config GDAL_PAM_ENABLED YES
gdalinfo --build
PAM_ENABLED=YES
OGR_ENABLED=YES
GEOS_ENABLED=YES
GEOS_VERSION=3.11.1-CAPI-1.17.1
PROJ_BUILD_VERSION=9.1.1
PROJ_RUNTIME_VERSION=9.1.1
COMPILER=GCC 12.2.0
 gdalinfo --version
GDAL 3.8.4, released 2024/02/08
also tried  gdal-3.6.2
OS is Ubuntu Aarch64
However, this does not result in the creation of an .aux.xml file. Could
you provide any insights into why the .aux.xml file may not be generated in
this instance?
Any assistance or suggestions you could offer would be greatly appreciated.
Best regards,
Shaima A.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240308/4d7389c2/attachment.htm>
