[gdal-dev] Using a "standard" argument parser for command line utilities?
thomas bonfort thomas.bonfort at gmail.com
Fri Mar 8 09:42:52 PST 2024
> I don't like that the behaviour of a command line depends on the
> configuration of the user (that is usually not aware of). So a command that
> works for me doesn't work for you. That is bad.
+1
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240308/857eb867/attachment.htm>
