[gdal-dev] New driver on doc index?
Even Rouault even.rouault at spatialys.com
Mon Mar 11 04:50:20 PDT 2024
Abel,
> Hi,
> I’m obtaining this error:
> /__w/gdal/gdal/doc/source/drivers/vector/miramon.rst: WARNING:
> document isn't included in any toctree
> The file of the rst is miramon.rst but the name of the driver is
> MiraMonVector (to make it different from MiraMonRaster, in a future).
> So, this is a problem?
the mismatch between the miramon.rst file and the name of the driver? no
but the warning is legit, and warnings are turned as errors in the doc
build process. Otherwise your new page would never have been linked from
anywhere else.
> or I should add miramon.rst in any index?
some quick googling of the error message would have lead you to
https://sphinx-intro-tutorial.readthedocs.io/en/latest/common_issues.html
which suggests to add the new file to a index.rst file, in that
instance: doc/source/drivers/vector/index.rst
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240311/c57661aa/attachment.htm>
