[gdal-dev] New driver on doc index?
Abel Pau a.pau at creaf.uab.cat
Mon Mar 11 04:58:50 PDT 2024
Oh,
I assumed that it was an internal error and not findable on google, but you’re right that the process is standard.
So, thanks for the answer!
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de Even Rouault via gdal-dev
Enviado el: dilluns, 11 de març de 2024 12:50
Para: gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] New driver on doc index?
Abel,
I’m obtaining this error:
/__w/gdal/gdal/doc/source/drivers/vector/miramon.rst: WARNING: document isn't included in any toctree
The file of the rst is miramon.rst but the name of the driver is MiraMonVector (to make it different from MiraMonRaster, in a future).
So, this is a problem?
the mismatch between the miramon.rst file and the name of the driver? no
but the warning is legit, and warnings are turned as errors in the doc build process. Otherwise your new page would never have been linked from anywhere else.
or I should add miramon.rst in any index?
some quick googling of the error message would have lead you to https://sphinx-intro-tutorial.readthedocs.io/en/latest/common_issues.html
which suggests to add the new file to a index.rst file, in that instance: doc/source/drivers/vector/index.rst
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240311/368acded/attachment.htm>
