[gdal-dev] GDAL 3.8.4 build on windows failed at linking
Fengting Chen fengting.chen at oracle.com
Mon Mar 11 13:49:51 PDT 2024
GDAL 3.8.4 build on Windows from VS2015 x64 command prompt: “cmake –build .” throws the following error (there are more similar errors):
cpl_vsil_az.obj : error LNK2001: unresolved external symbol __imp__curl_slist_append [E:\gdal-3.8.4\build\GDAL.vcxproj]
cmake options has:
set (GDAL_USE_CURL                ON   CACHE  BOOL "" FORCE)
set (CURL_INCLUDE_DIR             "E:/SDK/curl-8.6.0_1-win64-mingw/include" CACHE PATH "" FORCE)
set (CURL_LIBRARY_RELEASE         "E:/SDK/curl-8.6.0_1-win64-mingw/bin/libcurl-x64.lib" CACHE FILEPATH "" FORCE)
libcurl-x64.lib is the DLL stub. Using dumpbin on libcurl-x64.lib shows that “__imp_curl_slist_append” is available. But the linker error is “__imp__curl_slist_append” not found. There is an extra “_” in it.
Any idea why this error occurred?
Thanks!
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240311/42fa6367/attachment.htm>
