[gdal-dev] FW: [External] : GDAL 3.8.4 build on windows failed at linking
Fengting Chen fengting.chen at oracle.com
Tue Mar 12 09:48:40 PDT 2024
Resend with more information:
I am trying to build GDAL 3.8.4 on windows under VS2015. The build failed at linking stage that a bunch of external symbols not found, specifically the symbols in libproj, libcurl. I checked the dll library stub .lib for libproj and libcurl using “dumpbin” and found the symbols in the library a little different, for example the linker error shows “__imp__curl_slist_append” not found, the symbol output from the “dumpbin” is  “__imp_curl_slist_append” .
Any idea how to fix this?
Thanks!
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Fengting Chen via gdal-dev <gdal-dev at lists.osgeo.org>
Date: Monday, March 11, 2024 at 4:50 PM
To: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: [External] : [gdal-dev] GDAL 3.8.4 build on windows failed at linking
GDAL 3.8.4 build on Windows from VS2015 x64 command prompt: “cmake –build .” throws the following error (there are more similar errors):
cpl_vsil_az.obj : error LNK2001: unresolved external symbol __imp__curl_slist_append [E:\gdal-3.8.4\build\GDAL.vcxproj]
cmake options has:
set (GDAL_USE_CURL                ON   CACHE  BOOL "" FORCE)
set (CURL_INCLUDE_DIR             "E:/SDK/curl-8.6.0_1-win64-mingw/include" CACHE PATH "" FORCE)
set (CURL_LIBRARY_RELEASE         "E:/SDK/curl-8.6.0_1-win64-mingw/bin/libcurl-x64.lib" CACHE FILEPATH "" FORCE)
libcurl-x64.lib is the DLL stub. Using dumpbin on libcurl-x64.lib shows that “__imp_curl_slist_append” is available. But the linker error is “__imp__curl_slist_append” not found. There is an extra “_” in it.
Any idea why this error occurred?
Thanks!
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240312/c4a061d2/attachment.htm>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240312/c4a061d2/attachment.txt>
