[gdal-dev] FW: [External] : GDAL 3.8.4 build on windows failed at linking
Even Rouault even.rouault at spatialys.com
Tue Mar 12 09:56:33 PDT 2024
Not the answer you'll probably want to hear, but:
- Use an up-to-date compiler
- Use package distributions like vcpkg or conda-forge that already
brings all the dependencies "for free"
- It seems you mix builds of different compilers (VS vs mingw). That's a
bit asking for troubles ;-)
Le 12/03/2024 à 17:48, Fengting Chen via gdal-dev a écrit :
> Resend with more information:
> I am trying to build GDAL 3.8.4 on windows under VS2015. The build
> failed at linking stage that a bunch of external symbols not found,
> specifically the symbols in libproj, libcurl. I checked the dll
> library stub .lib for libproj and libcurl using “dumpbin” and found
> the symbols in the library a little different, for example the linker
> error shows “__imp__curl_slist_append” not found, the symbol output
> from the “dumpbin” is “__imp_curl_slist_append” .
> Any idea how to fix this?
> Thanks!
> *From: *gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of
> Fengting Chen via gdal-dev <gdal-dev at lists.osgeo.org>
> *Date: *Monday, March 11, 2024 at 4:50 PM
> *To: *gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Subject: *[External] : [gdal-dev] GDAL 3.8.4 build on windows failed
> at linking
> GDAL 3.8.4 build on Windows from VS2015 x64 command prompt: “cmake
> –build .” throws the following error (there are more similar errors):
> cpl_vsil_az.obj : error LNK2001: unresolved external symbol
> __imp__curl_slist_append [E:\gdal-3.8.4\build\GDAL.vcxproj]
> cmake options has:
> set (GDAL_USE_CURL                ON   CACHE  BOOL "" FORCE)
> set (CURL_INCLUDE_DIR "E:/SDK/curl-8.6.0_1-win64-mingw/include" CACHE
> PATH "" FORCE)
> set (CURL_LIBRARY_RELEASE
> "E:/SDK/curl-8.6.0_1-win64-mingw/bin/libcurl-x64.lib" CACHE FILEPATH
> "" FORCE)
> libcurl-x64.lib is the DLL stub. Using dumpbin on libcurl-x64.lib
> shows that “__imp_curl_slist_append” is available. But the linker
> error is “__imp__curl_slist_append” not found. There is an extra “_”
> in it.
> Any idea why this error occurred?
> Thanks!
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240312/2ce3f7ae/attachment-0001.htm>
