[gdal-dev] Internal libtiff version
Even Rouault even.rouault at spatialys.com
Mon Mar 18 05:51:39 PDT 2024
Hi Luís,
it depends on your GDAL was built.
You can check it  with "gdalinfo --format gtiff | grep LIBTIFF" and it
will return either LIBTIFF=INTERNAL or LIBTIFF=LIBTIFF, Version X.Y.Z
If it is with its internal libtiff copy, then it corresponds roughly to
the state of libtiff master at then time the GDAL release was done.
Looking at
https://github.com/OSGeo/gdal/blob/v3.6.4/frmts/gtiff/libtiff/tiffvers.h,
I see we were already past 4.4.0, so it is likely you have a GDAL build
against an external libtiff that wasn't as current as the GDAL build
Even
Le 18/03/2024 à 11:28, Luí s Moreira de Sousa via gdal-dev a écrit :
> Hi all,
> I am currently facing the error "PREDICTOR=2 is only supported with 64
> bit samples starting with libtiff > 4.3.0" with GDAL 3.6.4. Libtiff
> 4.3.0 was released in 2022, about a year before that version of GDAL.
> Is there a way to know which version of Libtiff is included with which
> version of GDAL? I searched the web site but could not find it.
> Thank you.
> Luís
> Sent with Proton Mail <https://proton.me/> secure email.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240318/196f5c9d/attachment.htm>
