[gdal-dev] Internal libtiff version
Luí­s Moreira de Sousa luis.de.sousa at protonmail.ch
Mon Mar 18 06:57:15 PDT 2024
Thank you Even, that is helpful. This GDAL build is the one available from the stable branch of the Ubuntu-GIS PPA. I will bring this to attention with that community.
Regards.
Luís
Sent with [Proton Mail](https://proton.me/) secure email.
On Monday, March 18th, 2024 at 1:51 PM, Even Rouault <even.rouault at spatialys.com> wrote:
> Hi Luís,
> it depends on your GDAL was built.
> You can check it with "gdalinfo --format gtiff | grep LIBTIFF" and it will return either LIBTIFF=INTERNAL or LIBTIFF=LIBTIFF, Version X.Y.Z
> If it is with its internal libtiff copy, then it corresponds roughly to the state of libtiff master at then time the GDAL release was done. Looking at https://github.com/OSGeo/gdal/blob/v3.6.4/frmts/gtiff/libtiff/tiffvers.h, I see we were already past 4.4.0, so it is likely you have a GDAL build against an external libtiff that wasn't as current as the GDAL build
> Even
> Le 18/03/2024 à 11:28, Luí s Moreira de Sousa via gdal-dev a écrit :
>> Hi all,
>> I am currently facing the error "PREDICTOR=2 is only supported with 64 bit samples starting with libtiff > 4.3.0" with GDAL 3.6.4. Libtiff 4.3.0 was released in 2022, about a year before that version of GDAL. Is there a way to know which version of Libtiff is included with which version of GDAL? I searched the web site but could not find it.
>> Thank you.
>> Luís
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240318/662df9b2/attachment-0001.htm>
