[gdal-dev] Censor area in tiles of aerial image
Mon Mar 18 16:14:36 PDT 2024
Carsten,
The gdal_rasterize command allows you to "burn in" polygons from an OGR
supported datasource into an existing raster.  If your raster is a 3 band
RGB file, you could use --burn 100 150 200 to burn in the RGB value
(100,150,200).   This will only work if the raster format you are using
supports update-in-place.
You would have to regenerate pyramids after this process -- they are not
automatically updated by GDAL when the "base layer" is updated.
Best regards,
Frank
On Mon, Mar 18, 2024 at 5:34 PM Carsten Lockenkötter via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> is it possible to censor specific areas of an aerial image using GDAL?
> I have several smaller tiles that I've already transformed into my desired
> coordinate system and generated internal pyramids.
> Subsequently, I would like to censor certain areas based on polygons
> (e.g., from a shapefile or an Oracle DB) (coloring them grayish).
> Set the color must be done after transforming coordinatesystem and
> generating pyramids.
> I usually use the compiled Windows binaries from gisinternals.com.
> Presumably, my plan doesn't work with that, right? At least I haven't
> found anything in that direction.
> I suppose this could be done with a Python, but I've never worked with
> Python before.
> Do I need to adjust the internal pyramids as well? Or do I have to
> recreate them?
> Could you please show me a brief example of how it could work, so I have
> an approach?
> I just need an idea of how to implement this and possibly some tips on
> what else I need to consider.
> Regards,
> Carsten
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up   | Frank Warmerdam,
light and sound - activate the windows | USA: +1 650-701-7823
<http://voice.google.com/calls?a=nc,%2B16507017823>
and watch the world go round - Rush    | CAN: +1 343-550-9984
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240318/c5a1a94e/attachment.htm>
