[gdal-dev] Censor area in tiles of aerial image
Carsten Lockenkötter carsten.lockenkoetter at web.de
Mon Mar 18 14:29:02 PDT 2024
is it possible to censor specific areas of an aerial image using GDAL?
I have several smaller tiles that I've already transformed into my desired
coordinate system and generated internal pyramids.
Subsequently, I would like to censor certain areas based on polygons (e.g.,
from a shapefile or an Oracle DB) (coloring them grayish).
Set the color must be done after transforming coordinatesystem and
generating pyramids.
I usually use the compiled Windows binaries from gisinternals.com.
Presumably, my plan doesn't work with that, right? At least I haven't found
anything in that direction.
I suppose this could be done with a Python, but I've never worked with
Python before.
Do I need to adjust the internal pyramids as well? Or do I have to recreate
them?
Could you please show me a brief example of how it could work, so I have an
approach?
I just need an idea of how to implement this and possibly some tips on what
else I need to consider.
Regards,
Carsten
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240318/135d07fe/attachment.htm>
