[gdal-dev] [External] : Re: Python binding installation on windows
Even Rouault even.rouault at spatialys.com
Tue Mar 19 13:44:15 PDT 2024
Le 19/03/2024 à 21:38, Fengting Chen a écrit :
> I copied out the command from install_python_Release.cmake and ran it
> manually. Then it worked. Not sure why the command not invoked. I
> don’t see error from “cmake –build . –target install –config Release”.
> My setuptools is 40.6.2.
Not sure if that's the reason, but that's pretty obsolete.
swig/python/pyproject.toml now requires setuptools >= 67
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240319/f8e1559d/attachment.htm>
