[gdal-dev] [External] : Re: Python binding installation on windows
Fengting Chen fengting.chen at oracle.com
Wed Mar 20 09:00:31 PDT 2024
Thanks for the suggestion. I can upgrade the setuptools and try again. Another question: is it possible to only build a specific driver plugin without rebuilding the GDAL?
Date: Tuesday, March 19, 2024 at 4:44 PM
To: Fengting Chen <fengting.chen at oracle.com>, gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
Subject: Re: [External] : Re: [gdal-dev] Python binding installation on windows
Le 19/03/2024 à 21:38, Fengting Chen a écrit :
I copied out the command from install_python_Release.cmake and ran it manually. Then it worked. Not sure why the command not invoked. I don’t see error from “cmake –build . –target install –config Release”.
My setuptools is 40.6.2.
Not sure if that's the reason, but that's pretty obsolete. swig/python/pyproject.toml now requires setuptools >= 67
http://www.spatialys.com<https://urldefense.com/v3/__http:/www.spatialys.com__;!!ACWV5N9M2RV99hQ!N3nIB7d9Q9apKmPbtbMITxjtMJmtZqXchODLrjPOsu8tiqHXsnajFBCx-lbUaTurwnt1im6MokPguTmhAGhhBLWTNET6$>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240320/269c7b64/attachment.htm>
