[gdal-dev] Experience with slowness of free() on Windows with lots of allocations?
Even Rouault even.rouault at spatialys.com
Wed Mar 20 17:55:28 PDT 2024
while investigating
https://github.com/OSGeo/gdal/issues/9510#issuecomment-2010950408, I've
come to the conclusion that the Windows heap allocation mechanism sucks.
Basically if you allocate a lot of heap regions of modest size with
malloc()/new[], the time spent when freeing them all with corresponding
free()/delete[] is excruciatingly slow (like ~ 10 seconds for ~ 80,000
allocations). The slowness is clearly quadratic with the number of
allocations. You only start noticing it with ~ 30,000 allocations. And
interestingly, another condition for that slowness is that each
individual allocation much be strictly greater than 4096 * 4 bytes. At
exactly that value, perf is acceptable, but add one extra byte, and it
suddenly drops. I suspect that there must be a threshold from which
malloc() starts using VirtualAlloc() instead of the heap, which must
involve slow system calls, instead of a user-land allocation mechanism.
Anyone has already hit that and found solutions? The only potential idea
I found until now would be to use a private heap with HeapCreate() with
a fixed maximum size, which is a bit problematic to adopt by default,
basically that would mean that the size of GDAL_CACHEMAX would be
consumed as soon as one use the block cache.
Even
http://www.spatialys.com
