[gdal-dev] Experience with slowness of free() on Windows with lots of allocations?
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Mar 21 00:27:12 PDT 2024
In my company we confirmed that "Windows heap allocation mechanism sucks."
Closing the application after using gtiff driver can take many seconds due
to memory deallocations.
One workaround was to use tcmalloc. I will ask my colleagues more details
next week.
On Thu, 21 Mar 2024, 01:55 Even Rouault via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> while investigating
> https://github.com/OSGeo/gdal/issues/9510#issuecomment-2010950408, I've
> come to the conclusion that the Windows heap allocation mechanism sucks.
> Basically if you allocate a lot of heap regions of modest size with
> malloc()/new[], the time spent when freeing them all with corresponding
> free()/delete[] is excruciatingly slow (like ~ 10 seconds for ~ 80,000
> allocations). The slowness is clearly quadratic with the number of
> allocations. You only start noticing it with ~ 30,000 allocations. And
> interestingly, another condition for that slowness is that each
> individual allocation much be strictly greater than 4096 * 4 bytes. At
> exactly that value, perf is acceptable, but add one extra byte, and it
> suddenly drops. I suspect that there must be a threshold from which
> malloc() starts using VirtualAlloc() instead of the heap, which must
> involve slow system calls, instead of a user-land allocation mechanism.
> Anyone has already hit that and found solutions? The only potential idea
> I found until now would be to use a private heap with HeapCreate() with
> a fixed maximum size, which is a bit problematic to adopt by default,
> basically that would mean that the size of GDAL_CACHEMAX would be
> consumed as soon as one use the block cache.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240321/413c0d1a/attachment.htm>
