[geomoose-psc] Trac notifications?
Eli Adam eadam at co.lincoln.or.us
Fri Apr 12 11:23:24 PDT 2013
Focusing back on Trac notifications and being responsive to tickets
that are entered (or funneling them back to the email list)...
Being the default owner means you have some obligation to clarify and
verify the ticket, discuss on the email list if needed, and then
provide some response to the reporter.  Then you can remove your
ownership, the main point is to not have tickets go unnoticed for
extended periods of time.  Changing the owner from yourself to
unassigned is a little tricky as I recall, but I think it is possible.
I've taken 'Docs' and 'Website', Brian has 'UserExtensions' and
'GeoMoose/PHP', which leaves,
        BuildTools
        Demo
        GeoMOOSE/JS
        Infrastructure
I think that Bob is volunteering for 'Demo'.
Is there any interest to have this email list get notice of the
tickets that no one claims?  I'll add this to the agenda of the next
PSC meeting.
To claim a component, in Trac, click on Admin tab, then click on
component and fill in your username in the owner field.
Eli
On Fri, Apr 12, 2013 at 9:21 AM, Brian Fischer <bfischer at houstoneng.com> wrote:
> I can take UserExtensions and GeoMoose/PHP.
> Brian Fischer, CFM
> Principal | GIS Project Manager
> Houston Engineering, Inc.
> O 763.493.4522 | D 763.493.6664 | M 763.229.2734
> -----Original Message-----
> From: Eli Adam [mailto:eadam at co.lincoln.or.us]
> Sent: Friday, April 12, 2013 11:21 AM
> To: Basques, Bob (CI-StPaul)
> Cc: Brian Fischer; James Klassen; geomoose-psc at lists.osgeo.org
> Subject: Re: [geomoose-psc] Trac notifications?
> Any takers for default owner of these ticket components:
>  BuildTools
>  Demo
>  GeoMOOSE/JS
>  GeoMOOSE/PHP
>  Infrastructure
>  UserExtensions
> Bob, are you expressing an interest in default owner of Demo components?
> We have the fairly informal demo gallery, http://www.geomoose.org/wiki/index.php/GeoMOOSE_Gallery
> Eli
> On Fri, Apr 12, 2013 at 9:19 AM, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us> wrote:
>> And PERL!!
>> Bobb
>> From: Brian Fischer [mailto:bfischer at houstoneng.com]
>> Sent: Friday, April 12, 2013 11:18 AM
>> To: James Klassen; Basques, Bob (CI-StPaul)
>> Cc: geomoose-psc at lists.osgeo.org
>> Subject: RE: [geomoose-psc] Trac notifications?
>> Sounds like we need some funding to try to port the PHP services to
>> Python J
>> Brian Fischer, CFM
>> From: geomoose-psc-bounces at lists.osgeo.org
>> [mailto:geomoose-psc-bounces at lists.osgeo.org] On Behalf Of James
>> Klassen
>> Sent: Friday, April 12, 2013 11:11 AM
>> To: Bob Basques
>> The big problem with more than one GeoMoose version at a time is
>> mod_php isn't very flexible.
>> GeoMoose JavaScript has no problem with multiple versions.
>> The problem is the PHP code is coupled to the JS version and is also
>> coupled to the MapServer version.  We tend to target the latest
>> MapServer available in MS4W to make life easy for our windows running users.
>> So we end up needing multiple MapServer versions to run multiple
>> GeoMoose versions  (which is easy enough for Perl/python/ruby
>> MapScript and also easy enough if we would decouple the (PHP) services
>> from the JS code similar to how things originally worked at the city)
>> but with PHP where everything essentially gets linked into Apache at runtime it makes life very difficult.
>> On Apr 12, 2013 11:01 AM, "Basques, Bob (CI-StPaul)"
>> All,
>> I have an interest in working on the "Demo" side of things, but I
>> would prefer to work in a separate container of sorts, maybe more of a
>> sandbox environment to be able to try different things, and to also
>> possibly leave them in place between versions, at least for a couple
>> of versions out.  I really like the sandbox approach used by
>> OpenLayers for demos of particular capabilities.  Using this sort of
>> model, it might be nice to see demos from more than one organization for different types of things over the long run.
>> The current demo looks to be tightly integrated with the GeoMoose
>> website on the whole, and based on the distribution methods that are
>> needed, this is probably a good thing.
>> So the question is, is there room for an extended set of demos,
>> possibly housed somewhere besides the GeoMoose web site and tied in as
>> a linked resource? This may be something that has some slight
>> dependency on the future abstraction of some of the GeoMoose tools as
>> well, at least in order for the idea to take off quicker.
>> bobb
>>>>  From: geomoose-psc-bounces at lists.osgeo.org [mailto:geomoose-psc-
>>>> bounces at lists.osgeo.org] On Behalf Of Eli Adam
>>>>  Sent: Friday, April 12, 2013 10:48 AM
>>>>  To: James Klassen
>>>>  Our docs partially suggest to confirm the bug on the list,
>>>>  http://geomoose.org/trunk/docs/faq.html?highlight=faq#how-should-
>>>>  i-report-a-bug
>>>>  and
>>>>  http://geomoose.org/trunk/howto/testing_reporting_ticketing.html#
>>>>  testing-reporting-ticketing
>>>>  I like the idea of confirming bugs in advance but think that in
>>>> practice we will have to in some way deal with bugs that don't
>>>> first go through the list.
>>>>  I've taken default ownership of the 'Docs' and 'Website'
>>>>  components, is anyone interested in any of these components and
>>>> following up on list or ticket?
>>>>      BuildTools
>>>>      Demo
>>>>      GeoMOOSE/JS
>>>>      GeoMOOSE/PHP
>>>>      Infrastructure
>>>>      UserExtensions
>>>>  Eli
>>>>  On Tue, Apr 9, 2013 at 6:53 PM, James Klassen
>>>> <klassen.js at gmail.com> wrote:
>>>>  > Generally, the owner of the ticket will get a notification.
>>>>  The
>>>>  > default owner is set at the component level.
>>>>  > On Tue, Apr 9, 2013 at 8:46 PM, Brian Fischer  >
>>>> <bfischer at houstoneng.com>  > wrote:
>>>>  >> I don't get any notification.
>>>>  >> I kind of like Jim's point that it would be nice to be
>>>> discussed on  >> the list first, but also see the point it would be
>>>> nice to be  >> notified if someone does enter a ticket so we can
>>>> follow up  >> immediately for clarification if the ticket is not
>>>> clear and  saves  >> time later trying to sort that out.
>>>>  >> Brian Fischer, CFM
>>>>  >> O 763.493.4522 | D 763.493.6664 | M 763.229.2734  >>  >>
>>>> -----Original Message-----  >> From:
>>>>  >> [mailto:geomoose-psc-bounces at lists.osgeo.org] On Behalf Of Eli
>>>> Adam  >> Sent: Tuesday, April 09, 2013 5:29 PM  >> To:
>>>> geomoose-psc at lists.osgeo.org  >> Subject: [geomoose-psc] Trac
>>>> notifications?
>>>>  >> Does anyone get Trac notifications when new tickets are  opened?
>>>> The  >> reason I ask is that if people enter tickets and don't get
>>>> any  >> response at all, it can be discouraging.
>>>>  >> I'm the default owner for Docs and website components so I get
>>>> those  >> notices.
>>>>  >> We could make this list the default owner, I also use  >>
>>>> http://trac.osgeo.org/geomoose/report/9 as a tab on my  homepage to
>>>> do  >> it the manual way.  Other ideas?
>>>>  >> Eli
>>>>  >> _______________________________________________
>>>>  >> geomoose-psc mailing list
>>>>  >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geomoose-psc
More information about the geomoose-psc mailing list
