[geomoose-psc] Trac notifications?
Eli Adam eadam at co.lincoln.or.us
Fri Apr 12 09:25:52 PDT 2013
On Fri, Apr 12, 2013 at 9:21 AM, Brian Fischer <bfischer at houstoneng.com> wrote:
> I can take UserExtensions and GeoMoose/PHP.
Great, Thanks Brian!
Eli
> Brian Fischer, CFM
> Principal | GIS Project Manager
> Houston Engineering, Inc.
> O 763.493.4522 | D 763.493.6664 | M 763.229.2734
> -----Original Message-----
> From: Eli Adam [mailto:eadam at co.lincoln.or.us]
> Sent: Friday, April 12, 2013 11:21 AM
> To: Basques, Bob (CI-StPaul)
> Cc: Brian Fischer; James Klassen; geomoose-psc at lists.osgeo.org
> Subject: Re: [geomoose-psc] Trac notifications?
> Any takers for default owner of these ticket components:
>  BuildTools
>  Demo
>  GeoMOOSE/JS
>  GeoMOOSE/PHP
>  Infrastructure
>  UserExtensions
> Bob, are you expressing an interest in default owner of Demo components?
> We have the fairly informal demo gallery, http://www.geomoose.org/wiki/index.php/GeoMOOSE_Gallery
> Eli
> On Fri, Apr 12, 2013 at 9:19 AM, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us> wrote:
>> And PERL!!
>> Bobb
>> From: Brian Fischer [mailto:bfischer at houstoneng.com]
>> Sent: Friday, April 12, 2013 11:18 AM
>> To: James Klassen; Basques, Bob (CI-StPaul)
>> Cc: geomoose-psc at lists.osgeo.org
>> Subject: RE: [geomoose-psc] Trac notifications?
>> Sounds like we need some funding to try to port the PHP services to
>> Python J
>> Brian Fischer, CFM
>> From: geomoose-psc-bounces at lists.osgeo.org
>> [mailto:geomoose-psc-bounces at lists.osgeo.org] On Behalf Of James
>> Klassen
>> Sent: Friday, April 12, 2013 11:11 AM
>> To: Bob Basques
>> The big problem with more than one GeoMoose version at a time is
>> mod_php isn't very flexible.
>> GeoMoose JavaScript has no problem with multiple versions.
>> The problem is the PHP code is coupled to the JS version and is also
>> coupled to the MapServer version.  We tend to target the latest
>> MapServer available in MS4W to make life easy for our windows running users.
>> So we end up needing multiple MapServer versions to run multiple
>> GeoMoose versions  (which is easy enough for Perl/python/ruby
>> MapScript and also easy enough if we would decouple the (PHP) services
>> from the JS code similar to how things originally worked at the city)
>> but with PHP where everything essentially gets linked into Apache at runtime it makes life very difficult.
>> On Apr 12, 2013 11:01 AM, "Basques, Bob (CI-StPaul)"
>> All,
>> I have an interest in working on the "Demo" side of things, but I
>> would prefer to work in a separate container of sorts, maybe more of a
>> sandbox environment to be able to try different things, and to also
>> possibly leave them in place between versions, at least for a couple
>> of versions out.  I really like the sandbox approach used by
>> OpenLayers for demos of particular capabilities.  Using this sort of
>> model, it might be nice to see demos from more than one organization for different types of things over the long run.
>> The current demo looks to be tightly integrated with the GeoMoose
>> website on the whole, and based on the distribution methods that are
>> needed, this is probably a good thing.
>> So the question is, is there room for an extended set of demos,
>> possibly housed somewhere besides the GeoMoose web site and tied in as
>> a linked resource? This may be something that has some slight
>> dependency on the future abstraction of some of the GeoMoose tools as
>> well, at least in order for the idea to take off quicker.
>> bobb
>>>>  From: geomoose-psc-bounces at lists.osgeo.org [mailto:geomoose-psc-
>>>> bounces at lists.osgeo.org] On Behalf Of Eli Adam
>>>>  Sent: Friday, April 12, 2013 10:48 AM
>>>>  To: James Klassen
>>>>  Our docs partially suggest to confirm the bug on the list,
>>>>  http://geomoose.org/trunk/docs/faq.html?highlight=faq#how-should-
>>>>  i-report-a-bug
>>>>  and
>>>>  http://geomoose.org/trunk/howto/testing_reporting_ticketing.html#
>>>>  testing-reporting-ticketing
>>>>  I like the idea of confirming bugs in advance but think that in
>>>> practice we will have to in some way deal with bugs that don't
>>>> first go through the list.
>>>>  I've taken default ownership of the 'Docs' and 'Website'
>>>>  components, is anyone interested in any of these components and
>>>> following up on list or ticket?
>>>>      BuildTools
>>>>      Demo
>>>>      GeoMOOSE/JS
>>>>      GeoMOOSE/PHP
>>>>      Infrastructure
>>>>      UserExtensions
>>>>  Eli
>>>>  On Tue, Apr 9, 2013 at 6:53 PM, James Klassen
>>>> <klassen.js at gmail.com> wrote:
>>>>  > Generally, the owner of the ticket will get a notification.
>>>>  The
>>>>  > default owner is set at the component level.
>>>>  > On Tue, Apr 9, 2013 at 8:46 PM, Brian Fischer  >
>>>> <bfischer at houstoneng.com>  > wrote:
>>>>  >> I don't get any notification.
>>>>  >> I kind of like Jim's point that it would be nice to be
>>>> discussed on  >> the list first, but also see the point it would be
>>>> nice to be  >> notified if someone does enter a ticket so we can
>>>> follow up  >> immediately for clarification if the ticket is not
>>>> clear and  saves  >> time later trying to sort that out.
>>>>  >> Brian Fischer, CFM
>>>>  >> O 763.493.4522 | D 763.493.6664 | M 763.229.2734  >>  >>
>>>> -----Original Message-----  >> From:
>>>>  >> [mailto:geomoose-psc-bounces at lists.osgeo.org] On Behalf Of Eli
>>>> Adam  >> Sent: Tuesday, April 09, 2013 5:29 PM  >> To:
>>>> geomoose-psc at lists.osgeo.org  >> Subject: [geomoose-psc] Trac
>>>> notifications?
>>>>  >> Does anyone get Trac notifications when new tickets are  opened?
>>>> The  >> reason I ask is that if people enter tickets and don't get
>>>> any  >> response at all, it can be discouraging.
>>>>  >> I'm the default owner for Docs and website components so I get
>>>> those  >> notices.
>>>>  >> We could make this list the default owner, I also use  >>
>>>> http://trac.osgeo.org/geomoose/report/9 as a tab on my  homepage to
>>>> do  >> it the manual way.  Other ideas?
>>>>  >> Eli
>>>>  >> _______________________________________________
>>>>  >> geomoose-psc mailing list
>>>>  >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geomoose-psc
More information about the geomoose-psc mailing list
