[geomoose-psc] Trac notifications?
Brian Fischer bfischer at houstoneng.com
Fri Apr 12 09:21:28 PDT 2013
I can take UserExtensions and GeoMoose/PHP.
Brian Fischer, CFM
Principal | GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
-----Original Message-----
Sent: Friday, April 12, 2013 11:21 AM
To: Basques, Bob (CI-StPaul)
Cc: Brian Fischer; James Klassen; geomoose-psc at lists.osgeo.org
Subject: Re: [geomoose-psc] Trac notifications?
Any takers for default owner of these ticket components:
 BuildTools
 Demo
 GeoMOOSE/JS
 GeoMOOSE/PHP
 Infrastructure
 UserExtensions
Bob, are you expressing an interest in default owner of Demo components?
We have the fairly informal demo gallery, http://www.geomoose.org/wiki/index.php/GeoMOOSE_Gallery
Eli
On Fri, Apr 12, 2013 at 9:19 AM, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us> wrote:
> And PERL!!
> Bobb
> From: Brian Fischer [mailto:bfischer at houstoneng.com]
> Sent: Friday, April 12, 2013 11:18 AM
> To: James Klassen; Basques, Bob (CI-StPaul)
> Cc: geomoose-psc at lists.osgeo.org
> Subject: RE: [geomoose-psc] Trac notifications?
> Sounds like we need some funding to try to port the PHP services to
> Python J
> Brian Fischer, CFM
> From: geomoose-psc-bounces at lists.osgeo.org
> [mailto:geomoose-psc-bounces at lists.osgeo.org] On Behalf Of James
> Klassen
> Sent: Friday, April 12, 2013 11:11 AM
> To: Bob Basques
> The big problem with more than one GeoMoose version at a time is
> mod_php isn't very flexible.
> GeoMoose JavaScript has no problem with multiple versions.
> The problem is the PHP code is coupled to the JS version and is also
> coupled to the MapServer version.  We tend to target the latest
> MapServer available in MS4W to make life easy for our windows running users.
> So we end up needing multiple MapServer versions to run multiple
> GeoMoose versions  (which is easy enough for Perl/python/ruby
> MapScript and also easy enough if we would decouple the (PHP) services
> from the JS code similar to how things originally worked at the city)
> but with PHP where everything essentially gets linked into Apache at runtime it makes life very difficult.
> On Apr 12, 2013 11:01 AM, "Basques, Bob (CI-StPaul)"
> All,
> I have an interest in working on the "Demo" side of things, but I
> would prefer to work in a separate container of sorts, maybe more of a
> sandbox environment to be able to try different things, and to also
> possibly leave them in place between versions, at least for a couple
> of versions out.  I really like the sandbox approach used by
> OpenLayers for demos of particular capabilities.  Using this sort of
> model, it might be nice to see demos from more than one organization for different types of things over the long run.
> The current demo looks to be tightly integrated with the GeoMoose
> website on the whole, and based on the distribution methods that are
> needed, this is probably a good thing.
> So the question is, is there room for an extended set of demos,
> possibly housed somewhere besides the GeoMoose web site and tied in as
> a linked resource? This may be something that has some slight
> dependency on the future abstraction of some of the GeoMoose tools as
> well, at least in order for the idea to take off quicker.
> bobb
>>>  From: geomoose-psc-bounces at lists.osgeo.org [mailto:geomoose-psc-
>>> bounces at lists.osgeo.org] On Behalf Of Eli Adam
>>>  Sent: Friday, April 12, 2013 10:48 AM
>>>  To: James Klassen
>>>  Our docs partially suggest to confirm the bug on the list,
>>>  http://geomoose.org/trunk/docs/faq.html?highlight=faq#how-should-
>>>  i-report-a-bug
>>>  and
>>>  http://geomoose.org/trunk/howto/testing_reporting_ticketing.html#
>>>  testing-reporting-ticketing
>>>  I like the idea of confirming bugs in advance but think that in
>>> practice we will have to in some way deal with bugs that don't
>>> first go through the list.
>>>  I've taken default ownership of the 'Docs' and 'Website'
>>>  components, is anyone interested in any of these components and
>>> following up on list or ticket?
>>>      BuildTools
>>>      Demo
>>>      GeoMOOSE/JS
>>>      GeoMOOSE/PHP
>>>      Infrastructure
>>>      UserExtensions
>>>  Eli
>>>  On Tue, Apr 9, 2013 at 6:53 PM, James Klassen
>>> <klassen.js at gmail.com> wrote:
>>>  > Generally, the owner of the ticket will get a notification.
>>>  The
>>>  > default owner is set at the component level.
>>>  > On Tue, Apr 9, 2013 at 8:46 PM, Brian Fischer  >
>>> <bfischer at houstoneng.com>  > wrote:
>>>  >> I don't get any notification.
>>>  >> I kind of like Jim's point that it would be nice to be
>>> discussed on  >> the list first, but also see the point it would be
>>> nice to be  >> notified if someone does enter a ticket so we can
>>> follow up  >> immediately for clarification if the ticket is not
>>> clear and  saves  >> time later trying to sort that out.
>>>  >> Brian Fischer, CFM
>>>  >> O 763.493.4522 | D 763.493.6664 | M 763.229.2734  >>  >>
>>> -----Original Message-----  >> From:
>>>  >> [mailto:geomoose-psc-bounces at lists.osgeo.org] On Behalf Of Eli
>>> Adam  >> Sent: Tuesday, April 09, 2013 5:29 PM  >> To:
>>> geomoose-psc at lists.osgeo.org  >> Subject: [geomoose-psc] Trac
>>> notifications?
>>>  >> Does anyone get Trac notifications when new tickets are  opened?
>>> The  >> reason I ask is that if people enter tickets and don't get
>>> any  >> response at all, it can be discouraging.
>>>  >> I'm the default owner for Docs and website components so I get
>>> those  >> notices.
>>>  >> We could make this list the default owner, I also use  >>
>>> http://trac.osgeo.org/geomoose/report/9 as a tab on my  homepage to
>>> do  >> it the manual way.  Other ideas?
>>>  >> Eli
>>>  >> _______________________________________________
>>>  >> geomoose-psc mailing list
>>>  >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geomoose-psc
More information about the geomoose-psc mailing list
