[geomoose-psc] Google Geocoder
Brian Fischer bfischer at houstoneng.com
Fri Jul 1 07:49:28 PDT 2016
Could we switch it to this?  https://open.mapquestapi.com/geocoding/ or https://www.mapbox.com/geocoding/    Still requires a key but maybe a little bit more flexible on licensing than Google or others.  Also uses OpenStreetMap data.
Brian Fischer
Vice President, GIS Project Manager
Houston Engineering, Inc.
O 763.493.4522 | D 763.493.6664 | M 763.229.2734
-----Original Message-----
From: geomoose-psc [mailto:geomoose-psc-bounces at lists.osgeo.org] On Behalf Of Dan Little
Sent: Friday, July 01, 2016 9:38 AM
To: James Klassen <klassen.js at gmail.com>
Cc: GeoMOOSE PSC <geomoose-psc at lists.osgeo.org>
Subject: Re: [geomoose-psc] Google Geocoder
Schuyler Earl. Good luck.  It's like 12 projects ago for him.
On Fri, Jul 1, 2016 at 9:35 AM, James Klassen <klassen.js at gmail.com> wrote:
> Do we know who was running geocoder.us?  Maybe we could get it fixed.
> On Jul 1, 2016 05:03, "Dan Little" <theduckylittle at gmail.com> wrote:
>> Hey Folks,
>> geocoder.us appears to be defunct. The website doesn't load and there
>> certainly does not appear to be any geocodes being returned.  This
>> was our default geocoder.
>> The other geocoder with which we have code is the Google Geocoder.
>> I'm fixing it up right now to work (it wasn't) and to also include an
>> appropriate credit/disclaimer.  However, I'm a bit worried as we are
>> probably running afoul the Google TOS.  I see a few options:
>> 1. Run with it. We're a very small fish in a very large pond.
>> 2. Do not include a Geocoder by default but provide instructions for
>> adding back in the Google geocoder (including setting an API key).
>> This runs ... "less" afoul the TOS depending on how you read them.
>> 3. Remove all the geocoders.  They're all broken.  Folks may not like
>> to see the code disappear.
>> Long term (and I will file a ticket to this regard) we should
>> probably write our own Geocoder instructions or write a crappy
>> DIY/off-the-shelf-libs geocoder that works with the default parcel
>> data.
>> Cheers,
>> -Duck
>> Reference tickets:
>> - https://github.com/geomoose/geomoose/issues/150
>> - https://github.com/geomoose/geomoose/issues/152
>> geomoose-psc mailing list
>> http://lists.osgeo.org/mailman/listinfo/geomoose-psc
More information about the geomoose-psc mailing list
