[geomoose-psc] Google Geocoder
Dan Little theduckylittle at gmail.com
Sat Jul 2 03:42:34 PDT 2016
I think that's fine. Not meant to make its way to distribution.
On Jul 2, 2016 12:40, "James Klassen" <klassen.js at gmail.com> wrote:
> Actually, you might want to check the zip and tarball, but local settings
> might not make it into the builds from the demo anyway.
> I can't remember the details off the top of my head though and don't have
> time to look for a couple days.
> On Jul 2, 2016 04:01, "Dan Little" <theduckylittle at gmail.com> wrote:
>> If Jim makes progress on getting geocoder.us back up and running we
>> can switch back to it.  For 2.9.1, I've added directions on how to get
>> the Google Geocoder to work and have added code that requires that an
>> API Key be added to local_settings.ini for it function.
>> This does mean, however, the demo on Geomoose.org will not have a
>> functioning geocoder.
>> Thanks folks!
>> On Fri, Jul 1, 2016 at 3:33 PM, James Klassen <klassen.js at gmail.com>
>> wrote:
>> > Fixing geocoder.us might be good overall though and if we help we
>> aren't
>> > grifting.
>> > The grifting argument applies to not using Google or others either which
>> > leaves us with nothing.
>> > On Jul 1, 2016 14:15, "Dan Little" <theduckylittle at gmail.com> wrote:
>> >> A pile of effort for minimal gain to our application.
>> >> If we want to release our stuff then. we can't be dependent on a
>> service
>> >> we were grifting.
>> >> On Jul 1, 2016 21:14, "James Klassen" <klassen.js at gmail.com> wrote:
>> >>> What about d) figure out what happened to geocoder.us?
>> >>> On Jul 1, 2016 14:07, "Eli Adam" <eadam at co.lincoln.or.us> wrote:
>> >>>> On Fri, Jul 1, 2016 at 9:31 AM, Basques, Bob (CI-StPaul)
>> >>>> <bob.basques at ci.stpaul.mn.us> wrote:
>> >>>> > More discussion needed for anything other than “a”.
>> >>>> > We have some options we’ve been using locally that might work as a
>> >>>> > replacement, but need to talk more about it first.  Hence my,
>> release
>> >>>> > now,
>> >>>> > and move to change later.
>> >>>> If we have no plans for "c" to come about in the near- or mid- term,
>> >>>> then "b" would be the immediate and mid-term option.  "a" to just
>> >>>> delay "b" is not a good option.  If we're going with "b" in the
>> >>>> mid-term, let's go with "b" now.
>> >>>> Those are my thoughts, Eli
>> >>>> > bobb
>> >>>> > On Jul 1, 2016, at 11:24 AM, Dan Little <theduckylittle at gmail.com>
>> >>>> > wrote:
>> >>>> > In terms of level of effort:
>> >>>> > a. This is already done in master.
>> >>>> > b. This would be 30-45 minutes worth of work.
>> >>>> > c. Probably an hour, maybe two hours with testing.
>> >>>> > I'm willing to do "b" if folks think that dropping the geocoder
>> from
>> >>>> > the demo is a viable move.
>> >>>> > On Fri, Jul 1, 2016 at 11:22 AM, Eli Adam <eadam at co.lincoln.or.us>
>> >>>> > wrote:
>> >>>> > Good point Bob, I think we need two discussions: What to do past
>> >>>> > 2.9.1? and What to do for 2.9.1?
>> >>>> > For beyond 2.9.1, I favor c, especially if Mapzen or something
>> else is
>> >>>> > a viable option.  If there aren't viable options, then b sounds
>> good
>> >>>> > for long term.
>> >>>> > For 2.9.1, I think any options will work except we might want to
>> >>>> > decide based on the long term.  i.e. if the long term route is b,
>> we
>> >>>> > should do that now for 2.9.1 too.
>> >>>> > Eli
>> >>>> > On Fri, Jul 1, 2016 at 9:16 AM, Basques, Bob (CI-StPaul)
>> >>>> > My vote would be for “a”, with a Note about probable deprecation of
>> >>>> > service
>> >>>> > in the demo.  Then figure out what the next version will look like.
>> >>>> > bobb
>> >>>> > On Jul 1, 2016, at 11:08 AM, Dan Little <theduckylittle at gmail.com>
>> >>>> > wrote:
>> >>>> > Should we:
>> >>>> > a. Deliver 2.9.1 with Google.
>> >>>> > b. Deliver 2.9.1 without any 'enabled' Geocoder (comment out the
>> entry
>> >>>> > in the mapbook) and write a quick "How To Enable The Googs".
>> >>>> > c. Deliver 2.9.1 with an alternative geocoder to replace
>> geocoder.us
>> >>>> > and leave the google code dormant as it was in 2.9.
>> >>>> > Aside:
>> >>>> > I'm not sure which of a-c would necessitate switching to 2.10 but
>> >>>> > these are all methods for addressing the same 'bug.'
>> >>>> > On Fri, Jul 1, 2016 at 10:41 AM, Eli Adam <eadam at co.lincoln.or.us>
>> >>>> > wrote:
>> >>>> > There is this,
>> https://mapzen.com/products/search/?lng=-124.01556&lat=44.66743&zoom=12
>> >>>> > not certain on licensing but seems very unrestricted.
>> >>>> > On Fri, Jul 1, 2016 at 8:03 AM, Dan Little <
>> >>>> > wrote:
>> >>>> > We could ship 2.9.1 with Google and do a next-step.  2.9.1, I
>> think,
>> >>>> > is basically ready for testing.
>> >>>> > On Fri, Jul 1, 2016 at 9:58 AM, James Klassen <
>> >>>> > wrote:
>> >>>> > It may be old school, but I didn't see any good alternatives
>> mentioned
>> >>>> > though.
>> >>>> > 1. Violate Google TOS
>> >>>> > 2. Cripple the Demo, but let people add it back.  Also, removes it
>> >>>> > from
>> >>>> > regular testing.
>> >>>> > 3. Who needs geocoders anyway?  This might be OK for the parcel app
>> >>>> > users
>> >>>> > because they probably already have better local data anyway.  But
>> it
>> >>>> > doesn't
>> >>>> > help anyone else.
>> >>>> > Also, this means the 2.9.0 on OSGeo Live should be fixed.
>> >>>> > On Jul 1, 2016 09:49, "Dan Little" <theduckylittle at gmail.com>
>> wrote:
>> >>>> > geocoder.us was useful but the momentum for geocoding TIGER files
>> in
>> >>>> > Berkeley databases is not considered particularly modern.
>> >>>> > On Fri, Jul 1, 2016 at 9:48 AM, James Klassen <
>> >>>> > wrote:
>> >>>> > I think an email saying we noticed it was down and offering to help
>> >>>> > maintain
>> >>>> > it might be worthwhile.
>> >>>> > Yes, a nice courtesy.
>> >>>> > I guess my real question is if geocoder.us is still useful to the
>> >>>> > community
>> >>>> > or has the world moved on to something else (OSM)?  If it is
>> useful to
>> >>>> > us
>> >>>> > and to others, we should look into helping maintain/support it.
>> >>>> > On Jul 1, 2016 09:37, "Dan Little" <theduckylittle at gmail.com>
>> wrote:
>> >>>> > Schuyler Earl. Good luck.  It's like 12 projects ago for him.
>> >>>> > On Fri, Jul 1, 2016 at 9:35 AM, James Klassen <
>> >>>> > wrote:
>> >>>> > Do we know who was running geocoder.us?  Maybe we could get it
>> fixed.
>> >>>> > On Jul 1, 2016 05:03, "Dan Little" <theduckylittle at gmail.com>
>> wrote:
>> >>>> > Hey Folks,
>> >>>> > geocoder.us appears to be defunct. The website doesn't load and
>> >>>> > there
>> >>>> > certainly does not appear to be any geocodes being returned.  This
>> >>>> > was
>> >>>> > our default geocoder.
>> >>>> > The other geocoder with which we have code is the Google Geocoder.
>> >>>> > I'm fixing it up right now to work (it wasn't) and to also include
>> >>>> > an
>> >>>> > appropriate credit/disclaimer.  However, I'm a bit worried as we
>> are
>> >>>> > probably running afoul the Google TOS.  I see a few options:
>> >>>> > 1. Run with it. We're a very small fish in a very large pond.
>> >>>> > 2. Do not include a Geocoder by default but provide instructions
>> for
>> >>>> > adding back in the Google geocoder (including setting an API key).
>> >>>> > This runs ... "less" afoul the TOS depending on how you read them.
>> >>>> > Running a demo of geocoding in GeoMoose seems fine as a
>> demonstration.
>> >>>> > We probably shouldn't distribute a working demo with an API key.
>> >>>> > Right now, it would take work to run a different demo than what we
>> >>>> > distribute as the demo.  So that makes a case for remove it from
>> the
>> >>>> > demo.
>> >>>> > With something like this, it seems providing directions and maybe
>> an
>> >>>> > example (but not working with an API key) is the correct path.
>> That
>> >>>> > allows the user to evaluate the TOS and whether they are
>> appropriate
>> >>>> > for them.
>> >>>> > 3. Remove all the geocoders.  They're all broken.  Folks may not
>> >>>> > like
>> >>>> > to see the code disappear.
>> >>>> > Long term (and I will file a ticket to this regard) we should
>> >>>> > probably
>> >>>> > write our own Geocoder instructions or write a crappy
>> >>>> > DIY/off-the-shelf-libs geocoder that works with the default parcel
>> >>>> > data.
>> >>>> > Let's avoid writing geocoders, even lame parcel ones.
>> >>>> > Best regards, Eli
>> >>>> > Cheers,
>> >>>> > -Duck
>> >>>> > Reference tickets:
>> >>>> > - https://github.com/geomoose/geomoose/issues/150
>> >>>> > - https://github.com/geomoose/geomoose/issues/152
>> >>>> > _______________________________________________
>> >>>> > geomoose-psc mailing list
>> >>>> > geomoose-psc at lists.osgeo.org
>> >>>> > http://lists.osgeo.org/mailman/listinfo/geomoose-psc
>> >>>> > "I'm not interested in preserving the status quo; I want to
>> overthrow
>> >>>> > it.”
>> >>>> > -  Niccolo Machiavelli
>> >>>> > "I like nonsense; it wakes up the brain cells."
>> >>>> > - Dr. Seuss
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20160702/dd60c645/attachment-0001.html>
More information about the geomoose-psc mailing list
