[geomoose-psc] Publishing the Ledger
Dan Little theduckylittle at gmail.com
Fri Dec 8 11:47:42 PST 2017
CSV is fine with me as well. That does allow for easy diffing and use of
spreadsheet programs as desired.  I will probably also include a "check
balance" Python script for doing some basic reporting.  There are CLI and
text based ledger programs.  I really don't want to go deep into a format
debate or over-do the accounting for what really is a simple
money-in-money-out + voting record.
In terms of backup and redundancy, I will have the repo cloned locally,
which gets backed up regularly, and those who have interest will also be
able to do pulls.  The bank account should also have some information and
I'll put Nancy and Steve's contact information in the repository so that if
something unfortunate were to happen, someone will be able to pick up the
torch and continue on.
On Fri, Dec 8, 2017 at 11:55 AM, Eli Adam <eadam at co.lincoln.or.us> wrote:
> Thanks for starting this Dan.  Github doesn't seem quite right (unless
> open source projects also got one private repo for security, finances,
> and other non-public issues)
> On Fri, Dec 8, 2017 at 7:25 AM, James Klassen <klassen.js at gmail.com>
> wrote:
> > Thoughts:
> > A plain text format might be better suited with git.  Org would be ideal
> (it
> I was also thinking of some form of text format.
> > can save formulas and recalculate like spreadsheets) except for most of
> the
> > magic only works in emacs, and despite emacs clearly being the one true
> > editor, I realize not everyone is ready to accept that yet.  But, some
> other
> > format like CSV or markdown table could work too.  Mostly, I'd like to be
> CSV is simple text and can still be used by spreadsheet programs.
> > able to use diff/blame to make it easy to audit who changed what when.
> Yes, changesets was the point.  I suppose that there is not going to
> be a lot of churn on this file so I could download 10 copies of binary
> files and open and look at them.  But that is using me (a human) to do
> diffs.
> > The geomoose.org server is only sporatically backed up right now (mostly
> > before and after larger system config changes and GeoMoose releases).  I
> > have been assuming the day to day changes are covered by what is on
> github
> > and people's local clones.  Thus is this isn't living on github, we
> should
> > be extra sure we are maintaining a separate  copies (that are kept up to
> > date) off server.
> > I have no problem with git over ssh (or git over email).  That is how it
> was
> > designed to work in the first place.  We could go as simple as using the
> > geomoose account or even easily setup gitolite.
> Every PSC meeting that has a report about finances could be a prompt
> for PSC members to copy the repo somewhere.
> > We should maybe look at using GPG signed commits (git commit -S) for this
> > repo.
> Maybe.  I don't expect that we'll have confusion over who is making
> the commits.
> Best regards, Eli
> > On Dec 8, 2017 8:44 AM, "Dan Little" <theduckylittle at gmail.com> wrote:
> >> Hey Folks,
> >> I have put together the start of a 'ledger'. Right now it's a
> spreadsheet
> >> in .ODS format. Barring objections, I'd like to create a repository on
> the
> >> web-server which can be accessed over SSH to store the ledger.  This can
> >> give folks who are interested access without putting _everything_ up on
> >> GitHub.
> >> For those interested, we have $1,126 available at present.
> >> Thanks again!
> >> _______________________________________________
> >> geomoose-psc mailing list
> >> geomoose-psc at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20171208/8a815c41/attachment-0001.html>
More information about the geomoose-psc mailing list
