[geomoose-psc] Publishing the Ledger
Eli Adam eadam at co.lincoln.or.us
Fri Dec 8 09:55:18 PST 2017
Thanks for starting this Dan.  Github doesn't seem quite right (unless
open source projects also got one private repo for security, finances,
and other non-public issues)
On Fri, Dec 8, 2017 at 7:25 AM, James Klassen <klassen.js at gmail.com> wrote:
> Thoughts:
> A plain text format might be better suited with git.  Org would be ideal (it
I was also thinking of some form of text format.
> can save formulas and recalculate like spreadsheets) except for most of the
> magic only works in emacs, and despite emacs clearly being the one true
> editor, I realize not everyone is ready to accept that yet.  But, some other
> format like CSV or markdown table could work too.  Mostly, I'd like to be
CSV is simple text and can still be used by spreadsheet programs.
> able to use diff/blame to make it easy to audit who changed what when.
Yes, changesets was the point.  I suppose that there is not going to
be a lot of churn on this file so I could download 10 copies of binary
files and open and look at them.  But that is using me (a human) to do
diffs.
> The geomoose.org server is only sporatically backed up right now (mostly
> before and after larger system config changes and GeoMoose releases).  I
> have been assuming the day to day changes are covered by what is on github
> and people's local clones.  Thus is this isn't living on github, we should
> be extra sure we are maintaining a separate  copies (that are kept up to
> date) off server.
> I have no problem with git over ssh (or git over email).  That is how it was
> designed to work in the first place.  We could go as simple as using the
> geomoose account or even easily setup gitolite.
Every PSC meeting that has a report about finances could be a prompt
for PSC members to copy the repo somewhere.
> We should maybe look at using GPG signed commits (git commit -S) for this
> repo.
Maybe.  I don't expect that we'll have confusion over who is making
the commits.
Best regards, Eli
> On Dec 8, 2017 8:44 AM, "Dan Little" <theduckylittle at gmail.com> wrote:
>> Hey Folks,
>> I have put together the start of a 'ledger'. Right now it's a spreadsheet
>> in .ODS format. Barring objections, I'd like to create a repository on the
>> web-server which can be accessed over SSH to store the ledger.  This can
>> give folks who are interested access without putting _everything_ up on
>> GitHub.
>> For those interested, we have $1,126 available at present.
>> Thanks again!
>> geomoose-psc mailing list
>> geomoose-psc at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
More information about the geomoose-psc mailing list
