[geomoose-psc] Feedback in testing PROJ v5.0.0 with GeoMOOSE
James Klassen klassen.js at gmail.com
Sun Feb 25 07:14:40 PST 2018
Do you want someone to try and build Proj5/GDAL/MapServer on Linux and test?
Is there a MS4W beta we can test against?
I see two likely options for what happened:
The simple answer is GeoMoose/the browser remembered where you were zoomed
to last.  Things working as expected after removing the URL after the # or
using the start over tool would confirm this.
The problematic answer is if MapServer's reprojection of the features from
26915 to 3857 changed and you had to zoom out from the default extent to
see the features.
On Feb 24, 2018 17:56, "Jeff McKenna" <jmckenna at gatewaygeomatics.com> wrote:
> Hi all,
> I have been testing the RC5 package of the upcoming PROJ 5.0.0 release (
> http://lists.maptools.org/pipermail/proj/2018-February/008045.html) on
> Windows in the MS4W environment (with MapServer-branch-7-0 and GDAL 2.2.3).
> I was shocked when I loaded the GM3 demo in my browser and saw a totally
> blank/white opening map image!!!?! (the normally green line layer of
> parcels, from demo/parcels/parcels.map, did not appear)
> I was stuck on that too long, wondering if I was somehow using the wrong
> API for this new PROJ (see upcoming release notes at bottom of
> http://lists.maptools.org/pipermail/proj/2018-February/007966.html), and
> going down many rabbit holes with logs etc.
> In the end.....if I zoom out then of course the parcels appear.
> Can someone else confirm this?  (it could of course only be happening in
> my environment)
> Does the stock GM3-demo opening map image appear normal for you, using
> PROJ 5.0.0 RC5 ?
> Please let me know.
> Thanks!
> (and now i can have a weekend, this was bugging me too much, ha!)
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> geomoose-psc mailing list
> geomoose-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geomoose-psc
URL: <http://lists.osgeo.org/pipermail/geomoose-psc/attachments/20180225/c358bc72/attachment.html>
More information about the geomoose-psc mailing list
