[Geomoose-users] Corrdinate Systems / Projections
Jay Kapalczynski jkapalczynski at ci.maple-grove.mn.us
Tue Jul 29 12:04:54 EDT 2008
Right now I have all my data projected in UTM
I want to use HENN County Projection....
What are my options that will not slow down the app
Can I change the Conifg.js file
What do I have to do that will use Henn Coordinate System and not cause
a slow down due to reprojecting on the fly
 * Unit Specification
var MAP_GROUND_UNITS = "M"; // "IN", "FT", "M", "MI" /* Sets the type of
Ground Units */
var MAP_COORDINATE_DISPLAY = true; /* Toggles whether to the map
coordinates should be shown in the footer. */
var MAP_SCALE_DISPLAY = true;              /* Toggles whether the scale
box should be shown */
var MAP_COORDINATE_SYSTEM = 'UTM-15'; /* Sets the Map Coordinate system,
for coordinate reprojection to Lat/Long */
var MEASURE_LENGTH_UNITS = "FT"; // "IN", "FT", "M", "MI"
var MEASURE_AREA_UNITS = "SQACRE"; // "SQIN", "SQFT", "SQM", "SQMI",
"SQACRE" ** "SQACRE" is acres, not "Square Acres"
var MAP_PIXELS_PER_INCH = 72; /* Sets the scrreen DPI for scale
calculations */
var ZOOM_BOX_SHAPE = 'box'; ///'scalebox' /* The rubber-band zoom in/out
can be forced to be displayed using the aspect ratio of the map */
Thanks
Jason Kapalczynski
City of Maple Grove
12800 Arbor Lakes Pkwy
GIS / IS
Office 763.494.6282
Fax:   763.494.6419
<mailto:jkapalczynski at ci.maple-grove.mn.us>
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080729/afd9d6e1/attachment.html
More information about the Geomoose-users mailing list
