[Geomoose-users] Corrdinate Systems / Projections
Dan Little danlittle at yahoo.com
Tue Jul 29 12:10:19 EDT 2008
1) Reproject All of Your Data to HCCS.
2) Change all of your settings for Extents to use valid HCCS coordinates.
3) Change the coordinate system to hennepin county coordinates ( there is an example of Dakota county coordinates in the demos ).
----- Original Message ----
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
To: geomoose-users at lists.sourceforge.net; geomoose-developers at lists.sourceforge.net
Sent: Tuesday, July 29, 2008 11:04:54 AM
Subject: [Geomoose-users] Corrdinate Systems / Projections
Right now I have all my data projected in UTM
I want to use HENN County Projection….
What are my options that will not slow down the app
Can I change the Conifg.js file
What do I have to do that will use Henn Coordinate System
and not cause a slow down due to reprojecting on the fly
 * Unit Specification
var MAP_GROUND_UNITS =
"M"; // "IN", "FT", "M", "MI"
/* Sets the type of Ground Units */
var MAP_COORDINATE_DISPLAY =
true; /* Toggles whether to the map coordinates should be shown in the footer.
var MAP_SCALE_DISPLAY = true;              /*
Toggles whether the scale box should be shown */
var MAP_COORDINATE_SYSTEM =
'UTM-15'; /* Sets the Map Coordinate system, for coordinate reprojection to
Lat/Long */
var MEASURE_LENGTH_UNITS =
"FT"; // "IN", "FT", "M",
"MI"
var MEASURE_AREA_UNITS =
"SQACRE"; // "SQIN", "SQFT", "SQM",
"SQMI", "SQACRE" ** "SQACRE" is acres, not
"Square Acres"
var MAP_PIXELS_PER_INCH = 72; /*
Sets the scrreen DPI for scale calculations */
var ZOOM_BOX_SHAPE = 'box';
///'scalebox' /* The rubber-band zoom in/out can be forced to be displayed
using the aspect ratio of the map */
Thanks
Jason Kapalczynski
City of Maple Grove
12800 Arbor Lakes Pkwy
GIS / IS
Office 763.494.6282
Fax:   763.494.6419
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080729/b79cb6bf/attachment.html
More information about the Geomoose-users mailing list
