[Geomoose-users] Want Maptips for group folders and layers
Fischer, Brian bfischer at houstonengineeringinc.com
Mon Jun 23 10:25:13 EDT 2008
Jim,
With a group you can specify a tip attribute like this:
<group title="Misc." expand="true" tip="Information about this folder
goes here">
With the layer you can specify a tip, help icon or metadata icon.  The
tip is a maptip versus the help and metadata icons are hyperlinks to
another webpage. Here would put all three on a layer:
    <map title="USGS Gaging Stations" default="true" tip="This layer is
visible at a 1:1,500,000 scale">
       <file>/ms4w/apps/GeoMOOSE/maps_statedemo/usgs/usgs.map</file>
       <meta>http://waterdata.usgs.gov/nwis</meta>
       <help>http://waterdata.usgs.gov/nwis</help>
  </map>
With this said anything is possible if you were to dig into the
javascript code and add the behaviour you want or hire a developer to
add the functionality you want to the GeoMOOSE base code.
Hope this helps,
Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jim
Dahl
Sent: Monday, June 23, 2008 9:11 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Want Maptips for group folders and layers
I want to use maptips to help users know how to better use the web site.
In particular I want a maptip to briefly describe the folder or
contents.  I probably could link to a help page from the table of
contents but not finding examples.  Any suggestions?
Jim Dahl, GISP
GIS Coordinator
Douglas County Public Works
509 3rd Ave W
PO Box 398
Alexandria MN 56308
V 320-762-2933
   320-763-6001
F 320-763-7955
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080623/0eb5a25e/attachment.html
More information about the Geomoose-users mailing list
