[Geomoose-users] Want Maptips for group folders and layers
Jim Dahl jim.dahl at mail.co.douglas.mn.us
Mon Jun 23 10:52:49 EDT 2008
One example is worth a lot.  Thanks!  I was using the wrong terminology
like 'title' or 'alt' like I used in the Mapmorph app.  I think the "How
To" gallery is great but I did not see an example for this.
	-----Original Message-----
	From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
	Sent: Monday, June 23, 2008 9:25 AM
	To: Jim Dahl; geomoose-users at lists.sourceforge.net
	Subject: RE: [Geomoose-users] Want Maptips for group folders and
layers
	Jim,
	With a group you can specify a tip attribute like this:
	<group title="Misc." expand="true" tip="Information about this
folder goes here">
	With the layer you can specify a tip, help icon or metadata
icon.  The tip is a maptip versus the help and metadata icons are
hyperlinks to another webpage. Here would put all three on a layer:
	    <map title="USGS Gaging Stations" default="true" tip="This
layer is visible at a 1:1,500,000 scale">
<file>/ms4w/apps/GeoMOOSE/maps_statedemo/usgs/usgs.map</file>
	       <meta>http://waterdata.usgs.gov/nwis</meta>
	       <help>http://waterdata.usgs.gov/nwis</help>
	  </map>
	With this said anything is possible if you were to dig into the
javascript code and add the behaviour you want or hire a developer to
add the functionality you want to the GeoMOOSE base code.
	Hope this helps,
	Brian
	Brian Fischer
	Houston Engineering, Inc.
	Maple Grove, MN
	(763) 493-4522
	From: geomoose-users-bounces at lists.sourceforge.net
[mailto:geomoose-users-bounces at lists.sourceforge.net] On Behalf Of Jim
Dahl
	Sent: Monday, June 23, 2008 9:11 AM
	To: geomoose-users at lists.sourceforge.net
	Subject: [Geomoose-users] Want Maptips for group folders and
layers
	I want to use maptips to help users know how to better use the
web site.  In particular I want a maptip to briefly describe the folder
or contents.  I probably could link to a help page from the table of
contents but not finding examples.  Any suggestions?
	Jim Dahl, GISP
	GIS Coordinator
	Douglas County Public Works
	509 3rd Ave W
	PO Box 398
	Alexandria MN 56308
	V 320-762-2933
	   320-763-6001
	F 320-763-7955
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20080623/27a61cb3/attachment.html
More information about the Geomoose-users mailing list
