[Geomoose-users] Displaying Print results in Geomoose 1.4.0
Fischer, Brian bfischer at houstonengineeringinc.com
Mon Nov 3 15:20:34 EST 2008
Matej,
I am just getting to release GeoMOOSE 1.6.1.  We have made a number of
bug fixes between 1.4 and 1.6.1 with the printing services.  I would try
the 1.6.1 version.  Should be out later today.
-Brian
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
Sent: Friday, October 24, 2008 5:52 AM
To: geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] Displaying Print results in Geomoose 1.4.0
my JavaScript knowledge is rather old and I am trying to have Printing
working. As I can see in FireBug, calling php/print.php works
successfully and text with hyperlinks to PDF, image files etc. and files
are created. However, when I click OK in the form where I set Map Title,
Page Size and Print Quality, I only get the message "Waiting ..." and
then an empty result page. I have found a solution with setting a div
with an id "content_results_form" class "visiblePanel", but then this
div is always visible. So, in other words, the div's class with an id
"content_results_form" doesn't get changed to "visiblePanel" from
"hiddenPanel". I don't remember changing anything in JS sources and this
might be a problem affecting other users as well.
Thank you for your help,
Matej Serc
matej at matnet.net
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081103/ec399b90/attachment.html
More information about the Geomoose-users mailing list
