[Geomoose-users] [Geomoose-developers] Buffer Tool
Fischer, Brian
bfischer at houstonengineeringinc.com
Mon Nov 3 15:26:01 EST 2008
Adam,
You should be able to change the xml definition from <service
title="Select by Buffer" default="true" locked="true"
cursor="url(cursors/pencil2.cur), auto" return="xml" display="div"
shape="box">
To
Shape="measurearea"
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
From: Adam Feidt [mailto:afeidt at edenprairie.org]
Sent: Tuesday, October 28, 2008 11:22 AM
To: Jay Kapalczynski
Cc: geomoose-developers at lists.sourceforge.net;
geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-developers] Buffer Tool
Yeah I've been playing around with this in the buffer tool, but it runs
a php script, which also needs to be modified. It keeps saying it must
be a poly. The select tool is probably ok as a box, but the buffer tool
really doesn't do any good on roads if it is a box select.
My graphic drawing tools don't work in the county demo either.
Adam M. Feidt
GIS Coordinator
City of Eden Prairie
8080 Mitchell Rd
Eden Prairie, MN 55344
phone# 952-949-8443
fax# 952-949-8334
From: Jay Kapalczynski [mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Tuesday, October 28, 2008 10:20 AM
To: Adam Feidt
Subject: RE: Buffer Tool
Line, Box, Polygon....respectively (see red highlight)
<service title="Select Feature Testing Line" default="true"
locked="true" cursor="url(cursors/select.cur), auto" shape="line"
type="inspect-search
<service title="Select Feature Testing Box" default="true" locked="true"
cursor="url(cursors/select.cur), auto" shape="box"
<service title="Select Feature Testing Measurearea" default="true"
locked="true" cursor="url(cursors/select.cur), auto" shape="measurearea"
ty
Think that should do it
-----Original Message-----
Sent: Tuesday, October 28, 2008 9:08 AM
To: geomoose-developers at lists.sourceforge.net
Subject: [Geomoose-developers] Buffer Tool
First and foremost, I just wanted to thank you guys for the new release
of GeoMoose. It is much better than GeoMoose 1.0, which I had been
using. You guys did a great job. Secondly, I was wondering if the
buffer tool could function more like the draw line tool. As it
currently stands you can only select by drawing a square box. This
makes it impossible to select or buffer a stretch of curvy road. For
example I want to buffer only Highway 101; if you could draw a line down
the center of Highway 101 then you could buffer it. You can't draw a
square around Highway 101 and get only the roads you want. You could
additionally add in a shortcut key to get the tool to draw a square box.
Adam M. Feidt
GIS Coordinator
8080 Mitchell Rd
phone# 952-949-8443
fax# 952-949-8334
From: geomoose-developers-request at lists.sourceforge.net
[mailto:geomoose-developers-request at lists.sourceforge.net]
Sent: Friday, October 24, 2008 9:29 AM
Subject: Geomoose-developers Digest, Vol 12, Issue 25
Send Geomoose-developers mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.sourceforge.net/lists/listinfo/geomoose-developers
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
geomoose-developers-owner at lists.sourceforge.net
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Geomoose-developers digest..."
Today's Topics:
1. Mailing Labels From the Select Tool Fixed (Jay Kapalczynski)
2. Re: [Geomoose-users] Service Types XML (Nelson Soto)
3. Re: [Geomoose-users] Service Types XML (Dan Little)
Message: 1
Date: Thu, 23 Oct 2008 13:36:19 -0500
From: Jay Kapalczynski <jkapalczynski at ci.maple-grove.mn.us>
Subject: [Geomoose-developers] Mailing Labels From the Select Tool
Fixed
To: "geomoose-developers at lists.sourceforge.net"
<geomoose-developers at lists.sourceforge.net>,
"geomoose-users at lists.sourceforge.net"
<geomoose-users at lists.sourceforge.net>
Cc: 'Nelson Soto' <NSoto at plotplans.com>, 'Nelson Soto'
<nellyfromma at gmail.com>
Message-ID:
<D7A5EAC385604446AB1DD24BF4F5A91807FC7F47E4 at MG-Mail.ci.maple-grove.mn.us
Content-Type: text/plain; charset="us-ascii"
Just thought I would pass this along to anyone interested...
I asked the question to get the select tools mailing labels to work like
the buffer tool....The buffer tool was not specific enough...with the
select tool I can select with Polygons, Lines, and Points...these means
are far more specific and make more sense for my application. Sometimes
you need random selections.....
GeoMOOSE was not designed for this....... I got this code from Mike
Hamby....Thanks Mike!
Anyways....the code is below....its basically the SELECT BUFFER code
...just replace you select code with this....and replace the blue code
with your specifics....
The main line allowing this is the negative buffer.... <input
type="hidden" name="buffer" value="-5"/>
Then you can change the shape="box" to allow a box, polygon, ,line etc
<service title="Select Feature" default="true" locked="true"
cursor="url(cursors/select.cur), auto" shape="box" type="inspect-search"
icon="shared/images/toolbar/draw_polygon.jpg"
highlight="shared/images/toolbar/draw_polygon_selected.jpg">
<url>php/buffer_select.php</url>
<input type="hidden" name="buffer" value="-5"/>
<input type="multipoint" name="coords"/>
<input type="hidden" name="shape" value="poly"/>
<input type="hidden" name="map"
value="/ms4w/apps/GeoMOOSE/maps_Crawford_UTM/select.map"/>
<input type="hidden" name="select"
<input type="hidden" name="select_layer"
value="Parcels:PIN">Parcels></input>
<input type="hidden" name="query_layer"
<input type="hidden" name="output" value="html"/>
</service>
Message: 2
Date: Fri, 24 Oct 2008 09:58:35 -0400
Subject: Re: [Geomoose-developers] [Geomoose-users] Service Types XML
To: "Nelson Soto" <NSoto at plotplans.com>,
<geomoose-users at lists.sourceforge.net>,
Message-ID:
<7BA6F57E003ADF4EA12DAA3043BB13D43B11E1 at geoexchange.DesLauriers.local>
Ok, well if it seems there is no up-to-date information regarding this
then how about the moose: tags returned from services?
Sent: Wednesday, October 22, 2008 2:52 PM
To: geomoose-users at lists.sourceforge.net;
Subject: Re: [Geomoose-users] Service Types XML
Is there an up-to-date Mapbook Reference guide? I would like to see all
of the acceptable input types at the moment.
Sent: Wednesday, October 22, 2008 2:31 PM
To: Nelson Soto; geomoose-users at lists.sourceforge.net;
The "types" are actually deprecated.
They used to imply how the search results were called and processed.
The only type that is honoured any more is "xml-post" which you can see
an example of operation in the Print service, which actually posts XML
to print.php for output.
Sent: Wednesday, October 22, 2008 1:29:00 PM
Subject: [Geomoose-users] Service Types XML
I am looking at the service definition located at GeoMoose's website.
http://www.geomoose.org/moose/index.php?option=com_content&task=view&id=
14&Itemid=29
I am trying to investigate the different parameters; particularly
'type'. I am looking at the Select Feature Service and notice the type
is "inspect-search". What is this? Are there more types than the 3
displayed on the site? Any help is appreciated..
Message: 3
Date: Fri, 24 Oct 2008 07:28:34 -0700 (PDT)
To: Nelson Soto <NSoto at plotplans.com>,
geomoose-users at lists.sourceforge.net,
Message-ID: <505703.86536.qm at web51412.mail.re2.yahoo.com>
Content-Type: text/plain; charset="windows-1252"
There is an intentional lack of documentation there, and that's because
it's a freakin' hack.
What happens when you return stuff from a service is this:
1) If it returns mapbook XML, then it processes it as if you've loaded
another mapbook, it can turn layers on, update them, etc.
2) If it returns HTML, it displays the HTML in the DIV, and then takes
commands from the <moose:mapbook>, it uses the different name space in
order to get the ease of HTML templating and get the power needed to do
two way communications between the Javascript client and the server-side
services.
To: Nelson Soto <NSoto at plotplans.com>;
Sent: Friday, October 24, 2008 8:58:35 AM
up-to-date information regarding this then how about the moose: tags
returned
from services?
[mailto:NSoto at plotplans.com]
2:52 PM
Service Types XML
guide? I would like to see all of the acceptable input types at the
moment.
2:31 PM
To: Nelson Soto;
Service Types XML
The
to
1:29:00 PM
Types XML
GeoMoose?s website.
14&Itemid=29
particularly ?type?. I am looking at the Select Feature Service and
notice the type is ?inspect-search?. What is this? Are there more
types than the 3 displayed on the site? Any help is appreciated..
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geomoose-developers at lists.sourceforge.net
End of Geomoose-developers Digest, Vol 12, Issue 25
challenge
prizes
world
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081103/8c3e3904/attachment.html
More information about the Geomoose-users
