[Geomoose-users] GeoMoose php
Fischer, Brian bfischer at houstonengineeringinc.com
Mon Nov 3 15:40:33 EST 2008
Michael,
You can use php to return mapbook fragments that will get put into the
TOC DIV.  It is not really setup to do this but that is one area we are
looking to improve in GM 2.0.
In your service definition you can specify what DIV you want the results
to go in from your php script.  The key is you need to have a div added
to the html file with that name.  Here's an example:
<service title="Search for Address" selectable="false" default="false"
locked="true" div="addresssearch">
			<url>../parcelmapsearch.php</url>
			<input type="hidden" name="field"
value="ADDRESS"/>
			<input type="user" name="sort" title="Sort
by:"/>
			<input type="user" name="searchval" title="Zoom
to Parcel#:"/>
		</service>
Brian Fischer
Houston Engineering, Inc.
Maple Grove, MN
(763) 493-4522
-----Original Message-----
From: Michael Reynolds [mailto:Mike.Reynolds at dot.state.mn.us]
Sent: Monday, November 03, 2008 6:44 AM
To: geomoose-developers at lists.sourceforge.net;
geomoose-users at lists.sourceforge.net
Subject: [Geomoose-users] GeoMoose php
I'm about 24 hours into learning php so I can have our GeoMoose site get
at more data.
Can php be used to populate any of the existing div's in the TOC panel?
or would php connections have to work through a separate window,
refreshing each time a request for data is run.  It seems that the TOC
is now built by mapserv via include templates and [ ] or do I have that
wrong?
I'm sure this isn't new ground for the experts or geomoose.  If
something like this is implemented through a current geomoose process,
just point me in the right direction.
Thank you.
This SF.Net email is sponsored by the Moblin Your Move Developer's
challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the
world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geomoose-users mailing list
Geomoose-users at lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
