[Geomoose-users] [Geomoose-developers] MySQL
Nelson Soto NSoto at plotplans.com
Fri Nov 7 11:48:24 EST 2008
It is placed in another file separate from the map file. Just make a new
text document and rename it to aqidata.ovf and put that information,
called xml, into the file.
From: Jay Kapalczynski [mailto:jkapalczynski at ci.maple-grove.mn.us]
Sent: Friday, November 07, 2008 11:39 AM
To: Nelson Soto; geomoose-developers at lists.sourceforge.net;
geomoose-users at lists.sourceforge.net
Subject: RE: [Geomoose-developers] [Geomoose-users] MySQL
Missed that...going to try that....thought it was just code that was
placed in another file...
Sent: Friday, November 07, 2008 10:08 AM
To: Jay Kapalczynski; geomoose-developers at lists.sourceforge.net;
The ogrvrt code is supposed to go in the ovf file you are told to make
here: http://mapserver.gis.umn.edu/docs/howto/ogrmysql/?searchterm=ovf
It technically doesn't matter where you save from what I gather; Just
point to wherever you put it in your map file. So, probably in the same
folder as your map file if you want to try to be consistent. It's really
up to you..
Sent: Friday, November 07, 2008 10:48 AM
To: 'geomoose-developers at lists.sourceforge.net';
'geomoose-users at lists.sourceforge.net'
Subject: Re: [Geomoose-developers] [Geomoose-users] MySQL
If I am doing something like this where does the  OGRVRTDataSource  code
have to be?
<OGRVRTDataSource>
    <OGRVRTLayer name="aqidata">
<SrcDataSource>MYSQL:aqiTest,user=uuuuu,password=ppppp,host=192.170.1.10
0,port=3306,tables=testdata</SrcDataSource>
        <SrcSQL>SELECT areaID, x, y, sampleValue FROM testdata</SrcSQL>
        <GeometryType>wkbPoint</GeometryType>
        <GeometryField encoding="PointFromColumns" x="x" y="y"/>
    </OGRVRTLayer>
</OGRVRTDataSource>
LAYER
    NAME "MyAqi"
    STATUS DEFAULT
    TYPE POINT
    CONNECTIONTYPE OGR
    CONNECTION "aqidata.ovf"
    DATA "aqidata"
    CLASS
       NAME "MyClass"
           STYLE
               SYMBOL 'circle'
               SIZE 15
               COLOR 0 255 0
           END
    END
END
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081107/b4c12aab/attachment.html
More information about the Geomoose-users mailing list
