[Geomoose-users] Image display covers up layers beyond itsextent
Jim Dahl jim.dahl at mail.co.douglas.mn.us
Fri Nov 7 17:18:39 EST 2008
Thanks Brian, and all,  This is the quickest fix ever.  I am still using
ECW and set  TRANSPARENT true  IMAGETYPE PNG24 and it works the way I
want.  You see the other image all around the border and the quality is
the same!
I have problems navigating the documentation, maybe need to spend a day
and thoroughly go through it all.
Jim
	-----Original Message-----
	From: Fischer, Brian [mailto:bfischer at houstonengineeringinc.com]
	Sent: Friday, November 07, 2008 3:12 PM
	To: Jim Dahl; Dan Little; geomoose-users at lists.sourceforge.net
	Subject: RE: [Geomoose-users] Image display covers up layers
beyond itsextent
	Use an imagetype of PNG24.  That will improve the quality. The
default output for PNG is only 8 bit.
	Take a look at outputformat on the MapServer documentation for
more help.
	Brian Fischer
	Houston Engineering, Inc.
	Maple Grove, MN
	(763) 493-4522
	From: Jim Dahl [mailto:jim.dahl at mail.co.douglas.mn.us]
	Sent: Friday, November 07, 2008 2:42 PM
	To: Dan Little; geomoose-users at lists.sourceforge.net
	Subject: Re: [Geomoose-users] Image display covers up layers
beyond itsextent
	Everyone, When I set transparency to true and tell it imagetype
is PNG, then the image around it shows.  However, the quality of the
image is poor so I cannot use it.  So I am back to using ECW.  Thanks
again.
	jim
		Sent: Friday, November 07, 2008 2:07 PM
		To: Jim Dahl; geomoose-users at lists.sourceforge.net
layers beyond its extent
		Images being served as a JPEG are not "see through" so
if you have an ECW that covers the City, mapserver will fill the rest of
the image with a color (typically white).  Transparency comes into play,
because if you serve the image as a PNG or GIF then the "white" becomes
"see through" (aka "transparent").
		This isn't a limitation of Mapserver or GeoMOOSE, it's a
limitation of the JPEG format.
		To: Dan Little <danlittle at yahoo.com>;
		Sent: Friday, November 7, 2008 2:01:50 PM
		The image is an ECW but JPG acts the same way.  My
question is why does transparency come into play when I do not want to
see under the image, I want to see beyond the extent of the image.  For
example the image is 1 mile by 1 mile and it still covers up the whole
county.  Is that because the mapserver still thinks the image is
county-wide?
		jim
			Sent: Friday, November 07, 2008 1:55 PM
			To: Jim Dahl;
covers up layers beyond its extent
			What type of layer is it?
			If it's raster it's a little harder to deal with
because it's probably being served as a JPEG and JPEG's don't support
transparency.
			If it's a GIF then it's pretty easy to just set
the image as transparent, so if there isn't any data it shouldn't show
up.
			To: geomoose-users at lists.sourceforge.net
			Sent: Friday, November 7, 2008 11:08:54 AM
			Subject: [Geomoose-users] Image display covers
			Hope to have better luck with this question..
Does anyone know how I can keep an image that covers only a city from
covering up another image below it that covers the entire county?  The
extent doesn't seem to work for me in the mapfile.
			thanks,
			Jim Dahl, GISP
			GIS Coordinator
			Douglas County Public Works
			509 3rd Ave W
			PO Box 398
			Alexandria MN 56308
			V 320-762-2933
			   320-763-6001
			F 320-763-7955
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081107/e8c8cd4a/attachment.html
More information about the Geomoose-users mailing list
