[Geomoose-users] PDF Printing - how to layer background
transparent?
Dan Little
danlittle at yahoo.com
Wed Nov 12 10:22:49 EST 2008
Something strange is happening with the mailing list... ah well...
I wrote to Nils that it is possible to convert to GIF output, but the image quality is greatly degraded.
----- Original Message ----
> From: CoFIS web | www.cofis.info <coffee at uni-bonn.de>
> To: Dan Little <danlittle at yahoo.com>
> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
> Sent: Wednesday, November 12, 2008 8:50:12 AM
> Subject: Re: [Geomoose-users] PDF Printing - how to layer background transparent?
> Dear Dan,
> thanks for your response. Is there a workaround for transparent layers for now
> (other than
> taking a screenshot)?
> Thank you,
> Nils
> Dan Little schrieb:
> > I'll have to look into this, I imagine it's because the Image is getting
> converted to RGB, then having transparency applied to it. The original "image
> stacking" code inside of the printing software was originally only tested
> against GIF and JPEG layers. We'll need to do some more work to make the 24-bit
> PNGs look good.
> >> Cc: geomoose-users at lists.sourceforge.net
> >> Sent: Wednesday, November 12, 2008 7:27:16 AM
> >> Subject: [Geomoose-users] PDF Printing - how to layer background transparent?
> >> Dear List,
> >> this has been asked before - but I cannot find a sufficient answer for me.
> >> I got the printing running in 1.6.1 but in the output I can only see the
> topmost layer with grey background/fill (same in html and pdf output). Forcing
> opacity on the topmost layer makes the lower one shine through. However, it
> looks by far not as good as the Geomoose map.
> >> The layers I want to print are shapes on my local system. In my mapfile I
> include the following output format options:
> >> NAME png
> >> DRIVER 'GD/PNG'
> >> MIMETYPE 'image/png'
> >> IMAGEMODE RGBA
> >> TRANSPARENT on
> >> EXTENSION 'png'
> >> The layer backgrounds appear transparently Firefox, IE7 and Safari on screen.
> How can I tell geomoose to do the same when printing?
> >> Thank you,
> >> Nils
> >> -- Center for Development Research
> >> Department of Ecology and Resource Management
> >> Walter-Flex-Strasse 3
> >> 53113 Bonn (Germany)
> >> Tel.: +49 (0) 228 - 73-1793
> >> FAX: +49 (0) 228 - 73-1889
> >> E-Mail: coffee at uni-bonn.de
> >> Web: http://www.cofis.info/atlas
> >> http://www.coffee.uni-bonn.de
> >> This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
> >> Build the coolest Linux based applications with Moblin SDK & win great prizes
> >> Grand prize is a trip for two to an Open Source event anywhere in the world
> >> http://moblin-contest.org/redirect.php?banner_id=100&url=/
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.sourceforge.net
> >> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users
