[Geomoose-users] PDF Printing - how to layer background transparent?
CoFIS web | www.cofis.info coffee at uni-bonn.de
Wed Nov 12 10:24:10 EST 2008
Ok, that works.
Thanks,
Nils
Dan Little schrieb:
> If the layer is an overlay, you could try using GIF output.  The image quality is not as good but it will function correctly.
> ----- Original Message ----
>> From: Nils Zierath <nils.zierath at uni-bonn.de>
>> To: Dan Little <danlittle at yahoo.com>
>> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>> Sent: Wednesday, November 12, 2008 8:49:26 AM
>> Subject: Re: [Geomoose-users] PDF Printing - how to layer background transparent?
>> Dear Dan,
>> thanks for your response. Is there a workaround for transparent layers for now
>> (other than taking a screenshot)?
>> Thank you,
>> Nils
>> Dan Little schrieb:
>>> I'll have to look into this, I imagine it's because the Image is getting
>> converted to RGB, then having transparency applied to it.  The original "image
>> stacking" code inside of the printing software was originally only tested
>> against GIF and JPEG layers.  We'll need to do some more work to make the 24-bit
>> PNGs look good.
>>>> From: CoFIS web | www.cofis.info
>>>> Cc: geomoose-users at lists.sourceforge.net
>>>> Sent: Wednesday, November 12, 2008 7:27:16 AM
>>>> Subject: [Geomoose-users] PDF Printing - how to layer background transparent?
>>>> Dear List,
>>>> this has been asked before - but I cannot find a sufficient answer for me.
>>>> I got the printing running in 1.6.1 but in the output I can only see the
>> topmost layer with grey background/fill (same in html and pdf output). Forcing
>> opacity on the topmost layer makes the lower one shine through. However, it
>> looks by far not as good as the Geomoose map.
>>>> The layers I want to print are shapes on my local system. In my mapfile I
>> include the following output format options:
>>>>     NAME        png
>>>>     DRIVER        'GD/PNG'
>>>>     MIMETYPE    'image/png'
>>>>     IMAGEMODE    RGBA
>>>>     TRANSPARENT    on
>>>>     EXTENSION    'png'
>>>> The layer backgrounds appear transparently Firefox, IE7 and Safari on screen.
>> How can I tell geomoose to do the same when printing?
>>>> Thank you,
>>>> Nils
>>>> -- Center for Development Research
>>>> Department of Ecology and Resource Management
>>>> Walter-Flex-Strasse 3
>>>> 53113 Bonn (Germany)
>>>> Tel.:   +49 (0) 228 - 73-1793
>>>> FAX:    +49 (0) 228 - 73-1889
>>>> E-Mail: coffee at uni-bonn.de
>>>> Web:    http://www.cofis.info/atlas
>>>>        http://www.coffee.uni-bonn.de
>>>> This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
>>>> Build the coolest Linux based applications with Moblin SDK & win great prizes
>>>> Grand prize is a trip for two to an Open Source event anywhere in the world
>>>> http://moblin-contest.org/redirect.php?banner_id=100&url=/
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.sourceforge.net
>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
>> -- Nils Zierath
>> E-Mail: nils.zierath at uni-bonn.de
>> Web:    http://www.coffee.uni-bonn.de
>>         http://www.zef.de
More information about the Geomoose-users mailing list
