[Geomoose-users] PDF Printing - how to layer background transparent?
CoFIS web | www.cofis.info coffee at uni-bonn.de
Wed Nov 12 10:32:58 EST 2008
no Dan, that was me. I sent my last message using an emailaddress that was not registered
to the list. When I got the error from majordomo I sent the message again with the right
sender address.
Sorry for that,
Nils
CoFIS web | www.cofis.info schrieb:
> Ok, that works.
> Thanks,
> Nils
> Dan Little schrieb:
>> If the layer is an overlay, you could try using GIF output.  The image quality is not as good but it will function correctly.
>> ----- Original Message ----
>>> From: Nils Zierath <nils.zierath at uni-bonn.de>
>>> To: Dan Little <danlittle at yahoo.com>
>>> Cc: GeoMoose Mailing list <geomoose-users at lists.sourceforge.net>
>>> Sent: Wednesday, November 12, 2008 8:49:26 AM
>>> Subject: Re: [Geomoose-users] PDF Printing - how to layer background transparent?
>>> Dear Dan,
>>> thanks for your response. Is there a workaround for transparent layers for now
>>> (other than taking a screenshot)?
>>> Thank you,
>>> Nils
>>> Dan Little schrieb:
>>>> I'll have to look into this, I imagine it's because the Image is getting
>>> converted to RGB, then having transparency applied to it.  The original "image
>>> stacking" code inside of the printing software was originally only tested
>>> against GIF and JPEG layers.  We'll need to do some more work to make the 24-bit
>>> PNGs look good.
>>>>> From: CoFIS web | www.cofis.info
>>>>> Cc: geomoose-users at lists.sourceforge.net
>>>>> Sent: Wednesday, November 12, 2008 7:27:16 AM
>>>>> Subject: [Geomoose-users] PDF Printing - how to layer background transparent?
>>>>> Dear List,
>>>>> this has been asked before - but I cannot find a sufficient answer for me.
>>>>> I got the printing running in 1.6.1 but in the output I can only see the
>>> topmost layer with grey background/fill (same in html and pdf output). Forcing
>>> opacity on the topmost layer makes the lower one shine through. However, it
>>> looks by far not as good as the Geomoose map.
>>>>> The layers I want to print are shapes on my local system. In my mapfile I
>>> include the following output format options:
>>>>>     NAME        png
>>>>>     DRIVER        'GD/PNG'
>>>>>     MIMETYPE    'image/png'
>>>>>     IMAGEMODE    RGBA
>>>>>     TRANSPARENT    on
>>>>>     EXTENSION    'png'
>>>>> The layer backgrounds appear transparently Firefox, IE7 and Safari on screen.
>>> How can I tell geomoose to do the same when printing?
>>>>> Thank you,
>>>>> Nils
>>>>> -- Center for Development Research
>>>>> Department of Ecology and Resource Management
>>>>> Walter-Flex-Strasse 3
>>>>> 53113 Bonn (Germany)
>>>>> Tel.:   +49 (0) 228 - 73-1793
>>>>> FAX:    +49 (0) 228 - 73-1889
>>>>> E-Mail: coffee at uni-bonn.de
>>>>> Web:    http://www.cofis.info/atlas
>>>>>        http://www.coffee.uni-bonn.de
>>>>> This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
>>>>> Build the coolest Linux based applications with Moblin SDK & win great prizes
>>>>> Grand prize is a trip for two to an Open Source event anywhere in the world
>>>>> http://moblin-contest.org/redirect.php?banner_id=100&url=/
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.sourceforge.net
>>>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
