[Geomoose-users] Printing PostGIS layer - error
Matej matej at matnet.net
Thu Nov 13 10:12:39 EST 2008
I turned the all error reporting on and found out that I forgot to copy the newly compiled mapscript.so with PostGIS support to the PHP's directory.
Anyways, we learn on mistakes. :)
Thanks and sorry for bothering,
Matej
matej at matnet.net
  ----- Original Message -----
  To: Matej ; geomoose-users at lists.sourceforge.net
  Cc: geomoose-developers at lists.sourceforge.net
  Sent: Thursday, November 13, 2008 3:28 PM
  Subject: Re: [Geomoose-users] Printing PostGIS layer - error
  Matej,
  Are you running the 1.6.X version of print.php or an earlier version?
  I do not see line 255 as a saveImage, on mine the only saveImage call is on line 278.
  Also can you post up the offending mapfile with the username/password redacted? That way we can get a little better idea what might be happening.
  To: geomoose-users at lists.sourceforge.net
  Sent: Thursday, November 13, 2008 8:17:10 AM
  Subject: [Geomoose-users] Printing PostGIS layer - error
  Hello everyone,
  I was finally able to solve that annoying encoding problem by getting all the data into the PostGIS database and selecting the appropriate client encoding - it works like a charm! :) Maybe this solution will help someone else.
  But I have another problem now: When I am trying to print the layer, which has the CONNECTIONTYPE POSTGIS instead of CONNECTIONTYPE OGR, I get an error: Fatal error: Call to a member function saveImage() on a non-object in /userdir/web/php/print.php on line 255. When I hide that layer and print that view, it works like it should.
  I can't find anything useful about this on the web and I will appreciate any ideas, so that I can get this web site public after all.
  Thanks,
  Matej Serc
  matej at matnet.net
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20081113/be3c33ef/attachment.html
More information about the Geomoose-users mailing list
