[Geomoose-users] Security and GeoMoose
Brent Fraser bfraser at geoanalytic.com
Thu Apr 2 10:59:54 EDT 2009
I'd say it's more of an enhancement for GM 2.0.  And I'm not even sure its possible.
  While it is possible to have all relative links in the .js reference a GEOMOOSE_ROOT (e.g. var XSL_RESULTS = GEOMOOSE_ROOT+'xsl/results.xsl';), I don't know if it can be done in the .HTML.  I suppose you could code absolute paths in the .HTML (<link href="/GEOMOOSE_ROOT/shared/styles.css"  rel="stylesheet" type="text/css"/>), then add an alias for GEOMOOSE_ROOT in the Web Server.   Hmmm, maybe the .HTML doesn't matter as I can change those few links by hand for a particular site anyways.
  In dealing with my security implementation below, the problem I had was with the relative paths used
through out the "compiled" GeoMoose JavaScript.  I could have changed them , but then upgrading the site (if there was ever a GM 1.7.0) would be a pain.  The solution would be to have a GEOMOOSE_ROOT set in the config.js (and have it set by default to "./"), and have all the GeoMoose JavaScript use GEOMOOSE_ROOT+ instead of hardcoding the relative path.
Thanks!
Brent Fraser
Dan Little wrote:
> What?! GeoMoose is not perfect? :-)
> As of now ... send me an email and I will get it put in.  We are doing a "GeoMOOSE Code Sprint" next week and Jim, Brian, and I will be hitting the GM2.0 code VERY hard but I will try to find some time to fix some 1.6 bugs.
> ----- Original Message ----
>> From: Brent Fraser <bfraser at geoanalytic.com>
>> To: geomoose-users at lists.sourceforge.net
>> Sent: Wednesday, April 1, 2009 2:14:08 PM
>> Subject: Re: [Geomoose-users] Security and GeoMoose
>> So where can I file a GeoMoose bug, I mean enhancement request?
>> Thanks!
>> Brent
>> Brent Fraser wrote:
>>>   I'm implementing Geomoose on a site that uses server-side scripting (asp) to
>> check credentials and deliver content.  So instead of allowing direct access to
>> statedemo.html (or mapserv.exe), there's a statedemo.asp in a different web
>> directory that rea
>>> ds statedemo.html from the filesystem and sends it to the browser (via IIS).
>> Since the ASP is in a different directory, the relative URLs in the GeoMoose are
>> invalid.
>>>   It would be nice if there was a way to easily set something like
>> "GEOMOOSE_ROOT" in the XML (an enhancement for GM2?).
>>>   BTW, I was able to solve the problem using a rewrite ISAPI filter on IIS
>> (the equivalent of apache's mod_rewrite).
>>> Thanks!
>>> Brent Fraser
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.sourceforge.net
>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
