[Geomoose-users] Security and GeoMoose
Brent Fraser bfraser at geoanalytic.com
Thu Apr 2 10:59:58 EDT 2009
Jim,
  Yes, but my path problem is with the relative URLs, not the filesystem mapfile paths.  And the "work-around" is to use mod_rewrite (or a rewrite isapi filter on IIS) as you've pointed out.  My hope was to have a more GeoMoose-specific solution to keep it simple (and avoid arguments with IT/Web admins).
Thanks!
Brent Fraser
Jim Klassen wrote:
> Is this materially different than what we are doing at the City where all the mapfiles are rooted at /datasets/something/something/a.map
> and calls to mapserver are like:
> /datasets/something/something/a.map?mode=map&mapext=.....
> and this is all pulled together by a mod_rewrite line in apache.conf?
> (Permissions are then controlled by location directives.)
>>>> Dan Little <danlittle at yahoo.com> 04/01/09 2:41 PM >>>
> What?! GeoMoose is not perfect? :-)
> As of now ... send me an email and I will get it put in.  We are doing a "GeoMOOSE Code Sprint" next week and Jim, Brian, and I will be hitting the GM2.0 code VERY hard but I will try to find some time to fix some 1.6 bugs.
> ----- Original Message ----
>> From: Brent Fraser <bfraser at geoanalytic.com>
>> To: geomoose-users at lists.sourceforge.net
>> Sent: Wednesday, April 1, 2009 2:14:08 PM
>> Subject: Re: [Geomoose-users] Security and GeoMoose
>> So where can I file a GeoMoose bug, I mean enhancement request?
>> Thanks!
>> Brent
>> Brent Fraser wrote:
>>>   I'm implementing Geomoose on a site that uses server-side scripting (asp) to
>> check credentials and deliver content.  So instead of allowing direct access to
>> statedemo.html (or mapserv.exe), there's a statedemo.asp in a different web
>> directory that rea
>>> ds statedemo.html from the filesystem and sends it to the browser (via IIS).
>> Since the ASP is in a different directory, the relative URLs in the GeoMoose are
>> invalid.
>>>   It would be nice if there was a way to easily set something like
>> "GEOMOOSE_ROOT" in the XML (an enhancement for GM2?).
>>>   BTW, I was able to solve the problem using a rewrite ISAPI filter on IIS
>> (the equivalent of apache's mod_rewrite).
>>> Thanks!
>>> Brent Fraser
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.sourceforge.net
>>> https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
