[Geomoose-users] Security and GeoMoose
Jim Klassen Jim.Klassen at ci.stpaul.mn.us
Thu Apr 2 09:49:56 EDT 2009
Is this materially different than what we are doing at the City where all the mapfiles are rooted at /datasets/something/something/a.map
and calls to mapserver are like:
/datasets/something/something/a.map?mode=map&mapext=.....
and this is all pulled together by a mod_rewrite line in apache.conf?
(Permissions are then controlled by location directives.)
>>> Dan Little <danlittle at yahoo.com> 04/01/09 2:41 PM >>>
What?! GeoMoose is not perfect? :-)
As of now ... send me an email and I will get it put in.  We are doing a "GeoMOOSE Code Sprint" next week and Jim, Brian, and I will be hitting the GM2.0 code VERY hard but I will try to find some time to fix some 1.6 bugs.
----- Original Message ----
> From: Brent Fraser <bfraser at geoanalytic.com>
> To: geomoose-users at lists.sourceforge.net
> Sent: Wednesday, April 1, 2009 2:14:08 PM
> Subject: Re: [Geomoose-users] Security and GeoMoose
> So where can I file a GeoMoose bug, I mean enhancement request?
> Thanks!
> Brent
> Brent Fraser wrote:
> >   I'm implementing Geomoose on a site that uses server-side scripting (asp) to
> check credentials and deliver content.  So instead of allowing direct access to
> statedemo.html (or mapserv.exe), there's a statedemo.asp in a different web
> directory that rea
> > ds statedemo.html from the filesystem and sends it to the browser (via IIS).
> Since the ASP is in a different directory, the relative URLs in the GeoMoose are
> invalid.
> >   It would be nice if there was a way to easily set something like
> "GEOMOOSE_ROOT" in the XML (an enhancement for GM2?).
> >   BTW, I was able to solve the problem using a rewrite ISAPI filter on IIS
> (the equivalent of apache's mod_rewrite).
> > Thanks!
> > Brent Fraser
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
More information about the Geomoose-users mailing list
