[Geomoose-users] How to print at specific scales?
Dan Little danlittle at yahoo.com
Fri Apr 24 16:49:35 EDT 2009
Apparently, we have the logic in there but it never gets called.
If you look at the prototype for the renderImage function, there is an optional named parameter, "preserveScale" ... add "true" to the end of the renderImage calls and it should start using the preserve scale functionality.
From: "Edward E. Boesenberg, III" <eboesenberg at niraengineers.com>
To: Dan Little <danlittle at yahoo.com>; geomoose-users at lists.sourceforge.net
Sent: Friday, April 24, 2009 1:53:38 PM
Subject: RE: [Geomoose-users] How to print at specific scales?
Where is the print option specified?  I looked at
the pdf php files and found some code in print.php (see below).
# Basic Printing Option
      renderImage($document,
$TempImage, $imagesize[0], $imagesize[1], $extent[0], $extent[1], $extent[2],
$extent[3]);
I
am guessing it is preserving the extent, how do I tell is to preserve scale.
[mailto:danlittle at yahoo.com]
Sent: Friday, April 24, 2009 2:14 PM
To: Edward E. Boesenberg, III; geomoose-users at lists.sourceforge.net
Subject: Re: [Geomoose-users] How to print at specific scales?
Right
now it has  two printing options (concerning scale):
1)
Preserve Extent
2)
Preserve Scale
But
there is not a current option to "print to X scale."  However,
if you manually set the scale in the application (say 1:100) then the map
should print to scale when "preserve scale" is selected for the
printing utility.
To: geomoose-users at lists.sourceforge.net
Sent: Friday, April 24, 2009 12:05:33 PM
Subject: [Geomoose-users] How to print at specific scales?
Is
there a way to get Geomoose to print at certain specified scales (ex. 1”=100’
or 1”=200’),  I don’t need the view to be at an exact scale just when I
use the “Print to PDF” function?
Edward
E. Boesenberg, III
CADD
/ GIS Manager
Nira
Consulting Engineers, Inc.
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20090424/af15a46d/attachment.html
More information about the Geomoose-users mailing list
