[Geomoose-users] Wms layer showing pinkish tiles.
Nils Zierath | Center for Development Research Bonn (ZEF) nils.zierath at uni-bonn.de
Wed Dec 16 05:29:52 EST 2009
Franz,
I pasted your mapbook settings into mine - red tiles resulting.
When changing the projection to *projection="EPSG:4326"* it works well.
I think in the mapbook you have to define the projection in which the
WMS is available. GeoMoose takes care of reprojecting this on the fly
into the one you use for your application.
Nils
FRANZ OKYERE schrieb:
> Hi Nils,
> In my mapsource I have the following
>  <map-source name='nasa' type='wms' tiled='false' projection='EPSG:2264'
> width='512' height='512'>
>   <url>http://onearth.jpl.nasa.gov/wms.cgi</url>
>   <layer name="global_mosaic"/>
>   <param name="format" value="image/jpeg"/>
>  </map-source>
> In my catalog;
>   <layer title="Sati" src="nasa/global_mosaic" status="on"/>
> Franz
>  > From: coffee at uni-bonn.de
>  > Subject: Re: [Geomoose-users] Wms layer showing pinkish tiles.
>  > To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
>  > Date: Fri, 11 Dec 2009 23:04:03 +0100
>  > Franz,
>  > maybe an error in your syntax? As well, the WMS might not
>  > be available at times or too slow (as happened to me when
>  > using NASA WMS).
>  > What did you put in your mapbook?
>  > Nils
>  > On Fri, 11 Dec 2009 18:53:17 +0000
>  > FRANZ OKYERE <franzzoa at hotmail.com> wrote:
>  > > Hi all, I thought in GM2, to use a wms service all you
>  > >need is to define it in the mapsource and then the
>  > >catalog..why then is my wms layer showing a pinkish
>  > >background after it has connected to the wms server?
>  > >Thanks. Franz Okyere. GIS specialist, SIT, Accra Ghana.
>  > > _________________________________________________________________
>  > > Got more than one Hotmail account? Save time by linking
>  > >them together
>  > > http://clk.atdmt.com/UKM/go/186394591/direct/01/
> New! Receive and respond to mail from other email accounts from within
> Hotmail Find out how. <http://clk.atdmt.com/UKM/go/186394593/direct/01/ >
> Return on Information:
> Google Enterprise Search pays you back
> Get the facts.
> http://p.sf.net/sfu/google-dev2dev
> Geomoose-users mailing list
> Geomoose-users at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geomoose-users
Nils Zierath
Department of Ecology and Resource Management
Walter-Flex-Strasse 3
53113 Bonn (Germany)
Tel.:   +49 (0) 228 - 73-1793
FAX:    +49 (0) 228 - 73-1889
E-Mail: nils.zierath at uni-bonn.de
Web:    http://www.coffee.uni-bonn.de
         http://www.zef.de
More information about the Geomoose-users mailing list
