[Geomoose-users] Wms layer showing pinkish tiles.
FRANZ OKYERE franzzoa at hotmail.com
Wed Dec 16 05:42:26 EST 2009
Cheers Nils, I'll be changing the projection to see if it works. I'm away from my laptop. Appreciate that. Franz.
> Date: Wed, 16 Dec 2009 11:29:52 +0100
> From: nils.zierath at uni-bonn.de
> To: franzzoa at hotmail.com
> CC: geomoose-users at lists.sourceforge.net
> Subject: Re: [Geomoose-users] Wms layer showing pinkish tiles.
> Franz,
> I pasted your mapbook settings into mine - red tiles resulting.
> When changing the projection to *projection="EPSG:4326"* it works well.
> I think in the mapbook you have to define the projection in which the
> WMS is available. GeoMoose takes care of reprojecting this on the fly
> into the one you use for your application.
> Nils
> FRANZ OKYERE schrieb:
> > Hi Nils,
> > In my mapsource I have the following
> >  <map-source name='nasa' type='wms' tiled='false' projection='EPSG:2264'
> > width='512' height='512'>
> >   <url>http://onearth.jpl.nasa.gov/wms.cgi</url>
> >   <layer name="global_mosaic"/>
> >   <param name="format" value="image/jpeg"/>
> >  </map-source>
> > In my catalog;
> >   <layer title="Sati" src="nasa/global_mosaic" status="on"/>
> > Franz
> >  > From: coffee at uni-bonn.de
> >  > To: franzzoa at hotmail.com; geomoose-users at lists.sourceforge.net
> >  > Date: Fri, 11 Dec 2009 23:04:03 +0100
> >  > Franz,
> >  > maybe an error in your syntax? As well, the WMS might not
> >  > be available at times or too slow (as happened to me when
> >  > using NASA WMS).
> >  > What did you put in your mapbook?
> >  > Nils
> >  > On Fri, 11 Dec 2009 18:53:17 +0000
> >  > FRANZ OKYERE <franzzoa at hotmail.com> wrote:
> >  > > Hi all, I thought in GM2, to use a wms service all you
> >  > >need is to define it in the mapsource and then the
> >  > >catalog..why then is my wms layer showing a pinkish
> >  > >background after it has connected to the wms server?
> >  > >Thanks. Franz Okyere. GIS specialist, SIT, Accra Ghana.
> >  > > _________________________________________________________________
> >  > > Got more than one Hotmail account? Save time by linking
> >  > >them together
> >  > > http://clk.atdmt.com/UKM/go/186394591/direct/01/
> > New! Receive and respond to mail from other email accounts from within
> > Hotmail Find out how. <http://clk.atdmt.com/UKM/go/186394593/direct/01/ >
> > Return on Information:
> > Google Enterprise Search pays you back
> > Get the facts.
> > http://p.sf.net/sfu/google-dev2dev
> > Geomoose-users mailing list
> > Geomoose-users at lists.sourceforge.net
> > https://lists.sourceforge.net/lists/listinfo/geomoose-users
> Nils Zierath
> Center for Development Research
> Department of Ecology and Resource Management
> Walter-Flex-Strasse 3
> 53113 Bonn (Germany)
> Tel.:   +49 (0) 228 - 73-1793
> FAX:    +49 (0) 228 - 73-1889
> E-Mail: nils.zierath at uni-bonn.de
> Web:    http://www.coffee.uni-bonn.de
>          http://www.zef.de
View your other email accounts from your Hotmail inbox. Add them now.
http://clk.atdmt.com/UKM/go/186394592/direct/01/
URL: http://lists.osgeo.org/pipermail/geomoose-users/attachments/20091216/bb454ab8/attachment.html
More information about the Geomoose-users mailing list
